603,900 active members*
4,530 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Manual entry as code in X2
    Sep 2005
    26
    Unhappy Manual entry as code in X2
    I am trying to use the manual entry to insert a M00 to rotate my part for second op maching. I choose to post as code and it still post as a comment.
    Apr 2005
    713
    Mine does the same, but I've never looked into it as I don't hesitate to hand edit my code if I feel the need. All I do is put a bunch of asterisks in the line so it's easy to find, then delete the parenthesis and asterisks and it's done.
    Apr 2003
    3578
    are you guys using older updated posts?
    Cadcam
    Sep 2005
    26
    Quote Originally Posted by cadcam View Post
    Yes. We updated from the old mastercam 9 post we had.
    Nov 2005
    174
    Have you tried force tool change when starting the secound op if your using the same tool?
  1. Fanuc 6T - comment entry
    By bkelsey in forum Fanuc
    Last Post: 05-17-2023, 03:25 AM
  2. Looking for entry level cnc set-up and programmers
    By Melissa Lawson in forum Employment Opportunity
    Last Post: 03-20-2008, 06:10 PM
  3. Entry Level CNC Lathes
    By big_mak in forum Uncategorised MetalWorking Machines
    Last Post: 12-28-2007, 06:48 AM
  4. G-code manual for Mach3 turn?
    By Green0 in forum Mach Lathe
    Last Post: 06-26-2007, 01:57 AM
  5. Data Entry During Machining
    By squarewave in forum CamSoft Products
    Last Post: 03-21-2005, 06:32 PM
