586,072 active members*
4,419 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > roland camm3 mill any info appreciated
    Apr 2007
    84
    I'd like to inquire about the roland camm3 mill. My main cincern would be the software and their inability to write g code with their software. Is there any way around this or is there a modern software available for this machine. The current software uses dos.
    I'm considering buying this mill , however, i'm stuck with the dilemma of the software and the limits at hand. Please help, and advice will be greatly appreciated.
    Mark
    Jul 2006
    887
    mark, i did a little google search and found that while its dos based it still does complex machining operations. While their control software doesnt create code, it looks as if many popular cad software apps are able to be used with the machine. I would do more research on the machine, it wasnt very clear from what I read (Something about BASIC) on how the machine is controlled.
    But I did find a few sites where one guy was using artcam as his cad and another guy was using autocad.........
  1. Replies: 299
    Last Post: 10-16-2022, 01:54 PM
  2. Roland Camm3 NC control
    By canalcop in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-01-2011, 07:52 PM
  3. Roland engraver/mill scripts for linux
    By gary-in-canada in forum OpenSource Software
    Last Post: 02-12-2010, 12:04 PM
  4. Starting knee-mill retrofit. Your input appreciated.
    By jamma in forum Uncategorised MetalWorking Machines
    Last Post: 03-01-2007, 05:41 PM
  5. any info is appreciated
    By bthomps5 in forum Mastercam
    Last Post: 04-12-2006, 04:17 AM
