586,655 active members*
3,106 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Polar interpolation problem
    Jul 2008
    5
    I'm about to threadmill a part here, the program is made in Gibbs and the machine is an puma mx2500lst.
    The problem is that when reading G12.1 I get this alarm: 145 Illegal command G112/G113
    G28U0.W0.V0.
    M289
    M101
    M170
    M06T2300
    T19000
    T23023
    M101
    M35
    G00G98Y0.Z5.C90.M26
    G97S200M33
    G54
    G00C0.
    G17
    M07
    C0.
    X46.
    M88
    G12.1
    G01X0.C23.F5000.
    M98P6
    G01Z5.F5000.
    G13.1
    M90
    Jul 2003
    263
    looks like your C value after the G12.1 is incorrect. the C value after the
    G12.1 becomes a linear dimension, not degrees. you have to post the subprogram 6 so some one can analyse the rest of the program, cause your mistake may be in there.
    If you can ENVISION it I can make it
    Jul 2008
    5
    Here's the sub-program:
    O6
    ( SUB NUMBER, 6 )
    G01W-29.215F200.
    G42U-7.778H3.889F5000.
    U.317H.333F200.
    G02U7.461H2.244W.215R4.223
    U12.931H-6.466W.477R6.466
    U-12.931H-6.465W.478R6.466
    U-12.931H6.465W.477R6.466
    U12.931H6.466W.477R6.466
    U7.284H-1.124W.182R6.466
    U3.637H-3.955W.215R4.223
    G01U-.113H-.364
    G40U-10.808H-1.023F5000.
    Z5.
    M99
    Mar 2008
    34
    G12.1 can't do 3 axis moves
    You can only interpolate with X and C when in G12.1. Try posting Gibbs without the G12.1, in other words, one line at a time. The program will be long, but it should work. Keep in mind, once you get outside of a 6" diameter bolt circle the accuracy can be questionable.
  1. How do you use polar interpolation
    By positiverake in forum G-Code Programing
    Last Post: 04-26-2024, 09:26 AM
  2. Polar interpolation post help
    By bassn_07 in forum Esprit
    Last Post: 06-26-2008, 09:26 AM
  3. Polar Interpolation
    By jackson in forum Daewoo/Doosan
    Last Post: 05-20-2008, 09:17 PM
  4. G12.1 Polar cordinate interpolation
    By theemudracer in forum G-Code Programing
    Last Post: 03-27-2008, 03:27 AM
  5. cnc lathe Cartesian-to-polar interpolation
    By knightlord in forum MetalWork Discussion
    Last Post: 01-31-2007, 07:24 AM
