586,102 active members*
2,462 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > need help finding specs on motor
Results 1 to 13 of 13
    Sep 2004
    179
    Hi all,
    I got 3 free stepper motors tonight. I belive NEMA 23 frame they are made by Japan Servo and have a number of KH56KM2-017 and the number of 7130 below that. Anyone know the voltage and amps for these?
    Darren
    Sep 2004
    179
    here are a couple of pics, Does Japan servo use a code of some sort that could tell me the amp rating and the voltage for these?
    Darren
    Japan Servo was no help they couldnt release the specs because they are custom made for a customer, I know the customer is SHARP as i pulled these motors out of a SHARP 3062 copier two nights ago.
    Attached Thumbnails Attached Thumbnails CNC log 059 copy.jpg   CNC log 062 copy.jpg
    Sep 2004
    179
    ok update, i pulled another motor today and got the driver circuit from one of the copiers. The pdf for the driver chip is here http://prelcoparts.com/datasheets/Pr...TK6712BMK4.pdf , this one is also is on the board http://prelcoparts.com/datasheets/Pr...TK6713BMK3.pdf . I found another stepper hooked up to the board same frame size but shorter in length. so now i am guessing that the motors are under a 3 amp rating and from what i can figure out on the schmatics motor voltage is somewhere in between 18-42 and since 90% of the stuff on this copier runs at 24V i'm guessing thats what they are. I have run one of these motors on my hobby cnc 3 axis chopper drive and it ran fine at 12v and 1.2A tho seemed weak because i could stop the shaft somewhat easy. the big question still is what amp draw are they? what would happen if i tried higher amp, burn a coil up if i went to high?
    Darren
    Oct 2004
    272
    You'll find some info on the motor series over at Japan Servo. Measure the resistance on each phase and you should be atleast a step further. There's always the possibility of mailing the company, too.
    - Lars Bjerke
    CNC-ing an SX3 to make a full-size CNC router to make some speakers. Why do it simple?
    Sep 2004
    179
    i'll check for the coil resistance. I emailed the japan servo site and they said they couldnt release info about the motors because they are custom built for the customer(SHARP) and they cant open the file unless the customer requests it.
    Apr 2005
    Any progress on the data-spec-hunting on the Japan-Servo motors?
    I got hold of 3 of these too.
    Tell me if you find anything
    / Ramsberg
    Sweden
    Oct 2004
    15
    ? about Stepper motors
    I aquired 3 Vexta 2-phase Model PK233-02BA Stepper Motors ( 6-wire ).
    It says they are 1.8 deg. 7.5 ohm DA 0.8A. Will these run a small CNC Router? I was gonna build the one HobbyCNC sells plans for? What do you think. Ill throw in a pic of them.
    Attached Thumbnails Attached Thumbnails servo 003_800x600.jpg   servo 004_800x600.jpg
    Feb 2005
    750
    Those Vextas will runfine on the hobby, as long as you can get the current doown around one amp Theyre rated .85A Bipolar or 1.2A Unipolar per phase. They are 0.121 oz/inSQUARED. I dont know what that means exactly, all this info is here
    http://www2.catalognavigator.com/ori...ktoname=&pane=
    That is Oriental's spec page. Good luck
    Halfnutz
    Oct 2004
    15
    Sounds Great. I wonder If a pc powersupply would work. If i can get the amps down. ?
    Oct 2004
    15
    Oh ya, Someone chime in on this one. What does 0.121 oz/inSQUARED.
    http://www2.catalognavigator.com/ori...=spec&filter=0. it says Rotor Inertia (oz-in2) here are the specs 0.3 oz-in2
    Feb 2005
    750
    OK, I see, it is above the rotor inertia, holding torque it says is 2.3/2.9 LB/IN. But I still dont know what that is in in/oz. Maybe just multiply the 2.3 or 2.9 time 16. Thats about right for those motors, 30-50 in/oz, I would imagine thats probably what it is.
    Halfnutz
    Oct 2004
    15
    Not bad for an ebay find. 3 steppers for 28 bucks with shipping. Total= $28.00. These are new motors. If I bought at the website where the specs were they were 56 bucks ea. No to build a controller board. What do you think about this one: http://www.uashem.com/trafid-190-35.html
    Steve
    May 2012
    Quote Originally Posted by CNC Darren View Post
    Darren
    Any specs on the motor. I got the exact one and I'm lost cant find any thing on it. Also I'm new at steppers any help will be apreciated.
  1. Vexta Stepper Motor Specs
    By met4life in forum Stepper Motors / Drives
    Last Post: 03-05-2011, 08:19 AM
  2. servo motor specs and help
    By cowanrg in forum Servo Motors / Drives
    Last Post: 06-12-2005, 12:11 AM
  3. Understanding (European) motor specs - help
    By WoodSnarfer in forum Servo Motors / Drives
    Last Post: 01-16-2005, 11:13 PM
  4. Help Me Figure the Specs of My Motor.
    By cbcnc in forum Stepper Motors / Drives
    Last Post: 08-14-2004, 04:21 PM
  5. Looking for some motor specs
    By Snipes44 in forum CNC Machine Related Electronics
    Last Post: 10-30-2003, 04:14 PM
