586,700 active members*
2,608 visitors online*
    Nov 2006
    26
    Wells Index Mill
    I have a Wells Index mill with 575 voltage -- can I convert it to 220 and have the motor rewired. If not what is the best way to hook this up in a residential garage?
    Horsepower is 1.5 RPMs 1800, 1.75AMP, PH3CY60, model MB8461-X.
    Any help will be greatly appreciated.
    24223
    Most likely most of the control electrics will be sourced from 240/120vac, so if you only have one three phase motor, then look at replacing it with a 220 3phase motor and use a VFD for conversion from 1ph to 3ph, you will also have speed control, if it does not already have.
    Feed the machine from a suitable 240v 1phase outlet, you may have to remove/change a control transformer or two.
    Check for any other 3phase devices though.
    Al.
    Albert E.
    Nov 2006
    26
    wells Index mill
    as I can see thire is only one motor I will sent some pic of the mill
    Nov 2006
    26
    wills Inder mill
    Al.
    as I can see thire is only one motor-but I have sent some pic of the mill if you could take a look at pic I post themon the site
  1. Wells Index Mill mystery knob...What's it for?
    By Chris64 in forum Uncategorised MetalWorking Machines
    Last Post: 10-01-2008, 05:56 PM
  2. Repairing or retrofitting a Wells Index
    By Aley in forum Uncategorised MetalWorking Machines
    Last Post: 09-04-2007, 10:03 AM
  3. Wells-Index Z-Axis Replacement Gear
    By askjerry in forum Uncategorised MetalWorking Machines
    Last Post: 08-06-2007, 05:19 PM
  4. Wells Index model 747
    By wall!@# in forum Knee Vertical Mills
    Last Post: 04-27-2007, 08:17 PM
  5. Wells Index cnc iron ....FREE...but
    By gus in forum Bridgeport / Hardinge Mills
    Last Post: 11-16-2005, 07:13 PM
