586,103 active members*
3,447 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Series C Amplifier Voltage Issues
    Feb 2006
    9
    I have been chasing this issue for at least a month now.
    I have a Fanuc 18M Control on a Grinder. My first issue was a 414 error on the Y axis. Long story short after talking with Fanuc:
    First diagnostic was Amplifier so I replaced that: Worked for a few days and repeated Error
    Second diagnostic was motor: I got the rebuilt, worked for a few days and repeated the Error
    Following the books with a 1 bit in the OFS in DNG 204 leads me to Motherboard and Axis Daughter Boards. So we found rebuilts of both: Worked for a few hours then repeated error.
    Next we looked at the Amplifier again, as we could have had a bad motor, replaced amplifier and the bad motor took the amplifier out again. Company that sent us the amp kindly replaced it under warranty and we tried again. Worked for a few hours and repeated.
    Next we swapped the motors and the issue follow the motor. So we bit the bullet and bought a brand new motor from Fanuc: That worked for a day and a half, but now brought us a more common 411 error and 410 error. Now if I do get a 414 error which only seems to happen if I can actually get the machine to move and it over travels. I get an 8 on the Amp LED.
    Now I am looking back at the amplifier. I am getting a solid 220v into all the amps, but on my Y axis Amp I am fluctuation from 110V to 160v (idle) on all three legs output. While the other Amps are solid at 160V constant. Not sure what this means but since X and Y are the same motor, i would think the output voltages should be the same.
    The issue now follows the amp and not the motor, if I change Amplifiers
    I have tested connections on the cables and see no short to ground and have continuity through all the wires.
    Any thoughts as I wait for Fanuc to call me back again???
    Thanks for any info
    Josh
    24221
    IIRC these are the drives with the sub miniature connectors plugged into the bottom?
    I had one where the connector was bad, if I wedged the connector up into the socket it would run.
    Due to all the different scenarios you have, with new motor, new amp, it sounds like it could be cable/connector problem.
    Al.
    Albert E.
  1. TechoCNC LC series issues
    By Python in forum Commercial CNC Wood Routers
    Last Post: 11-25-2007, 03:12 AM
  2. Amplifier Control Advice (Anilam 1100 BP Series II)
    By JHCHOPPERS in forum Bridgeport / Hardinge Mills
    Last Post: 11-09-2007, 08:33 PM
  3. o-m series alarm issues.
    By faunc-in-crazy in forum Fanuc
    Last Post: 09-18-2007, 03:44 PM
  4. Replies: 4
    Last Post: 09-14-2007, 04:34 PM
  5. BP Series 1 with Mach3- Z axis limits issues
    By bbuonomo in forum Bridgeport / Hardinge Mills
    Last Post: 10-13-2006, 10:39 AM
