586,119 active members*
3,618 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > I/R Module General Fault
Results 1 to 6 of 6
    On Hurco BMC30HTZM I am getting an I/R Module General Fault. It will not reset and repeats the same fault. Where do I look?
    Jun 2008
    1104
    Open the cabinet doors while keeping the keyswitch turned. Keep it turned until you have pulled the switches in the top corners until they click. Then release the keyswitch.
    Look at the I/R module (big beige unit in the middle upper of the cabinet, no display, just fault / status lights).
    See if there are any fault LEDs on.
    If just yellow and/or green, go to the console, press "manual" press and hold "power" press "reset servos and spindle" then press and hold "start" as well as "power". Do the servos start now with the power and start buttons held?
    Let me know.....
    Oct 2008
    If you still have the problem, please advise,we have a solution (same problem on a BMC30HT with SIEMENS drives.
    Nov 2010
    We have the same fault coming up on a HURCO 4020 HT , it lets us move in the Z & X but when you try to move in the Y this fault comes up . Does this point to a faulty Y drive ?? as you all probably know HURCO's can be very missleading when it comes to telling you whats wrong with them !!
    Mar 2018
    Re: I/R Module General Fault
    I have the same fault. Prompting IR general fault on the screen sometimes during switching on, sometimes after a few minutes milling. It is a Hurco VMX 24 HT.
    We changed E/R modul / LT modules and after a while the same situation.
    Please if you knew a solution for this problem let me knew how to solve this problem with the siemens drive chain.
    These needs must be understood that the entire chain of high-precision instruments of production technology must have perfect control in the chain.
  1. EZ-TRAK - “Possible Pointer Error - General Protection Fault”
    By Litespeed in forum Bridgeport / Hardinge Mills
    Last Post: 12-29-2015, 10:41 PM
  2. Fanuc Power supply module fault
    By Dean-R in forum Fanuc
    Last Post: 12-13-2013, 06:10 PM
  3. Replies: 1
    Last Post: 07-27-2013, 03:53 PM
  4. Replies: 3
    Last Post: 05-18-2011, 05:26 AM
