586,108 active members*
3,139 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2) > Sine wave for 5 phase 10 wire stepper (non-stared)
    Jul 2008
    4
    Hi
    I'm building a new controller for a leath using EMC.
    Most of the electronics in the leath were lightning struck, so were junk, the heavier stuff was OK. Using two parallel ports, I have every thing mostly working under control of EMC except the stepper motors...
    They are apparently a high end (for their day) 5 phase motor with 10 leads in a non-stared configuration. The drive amps are OK, so will reuse them, but they need a +/- 8 volt 5 phase sine wave to drive them. The manufacture (South Bend) had used a micro processor to control 5 digital-to-analog convertors. This way they could make a sine wave that could be run at a wide range of frequencies and even frozen or reversed. Slick.
    I dicided to follow their lead and do much the same thing, just with a bit newer processor.
    Has anyone already done something like this? If so, do you have a design or any design tips that could save me some hassle?
    I'm a bit undecided if it would be better to use step/dir. or speed/dir. control. It seems to me that speed and direction would be better as it would involve less communication between the PC and the signal generator via a parallel port.
    Jul 2008
    411
    I would have thought the deciding factor would be what EMC prefers to control them with. Creating a 5-channel sine wave from a step/dir signal using a current microprocessor with internal or external DACs is relatively easy and there's sample code around for ATMEL and PIC processors that would give you a head start (albeit 2 phase, but the concepts are similar).
    As I understood it your choices are step/dir for stepper drivers or speed/direction plus encoder so that EMC plays the part of a servo controller. I suspect the latter is infinitely harder to get working effectively and efficiently but no doubt someone will be along in a minute to contradict me...
    Mar 2008
    267
    Yes I had to generate multiple analogue control voltages with a micro.
    I used atmel ATmega16 with linear technologies D/A converter chips sitting on I2C buss.
    All A/D chips sit on same clock and serial data line the micro uses one of the ports to select which A/D is to be updated.
    You can write a look up table to do the appropriate D/A output , a modulo 5 counter to select the correct channel and voila Bob's Your uncle.
    The beauty of this scheme is that the D/A converters retain last analogue value
    This gives You a fairly quick update rate for a five phase output.
    from memory update rate was about 14 clock cycles per channel.
    I used this to control gains and AGC loops in an RF signal processor but same same
  1. 5 Phase/ 5 wire stepper drivers.
    By jonandyev in forum Open Source Controller Boards
    Last Post: 09-24-2020, 06:37 PM
  2. Sine Plates, Sine Bars, Sine Fixtures . . .
    By widgitmaster in forum MetalWork Discussion
    Last Post: 07-27-2013, 04:52 PM
  3. Vexta 5-phase / 10 Wire Steppers
    By peiboy in forum Stepper Motors / Drives
    Last Post: 08-18-2009, 07:17 PM
  4. sine wave Linear Encoder ??
    By Danii in forum Linear and Rotary Motion
    Last Post: 11-01-2007, 02:44 PM
  5. Gettys N360 three phase half wave
    By bsharp in forum Servo Motors / Drives
    Last Post: 08-06-2007, 03:06 AM
