603,424 active members*
3,125 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Fruit Machine Stepper Motors - Any Good?
    Oct 2004
    26
    I found 3 motors from an old fruit machine:
    It has 24 steps per resolution and I measoure 54 Ω/27Ω, 6 wires. The shaft is 6.35 mm and the mounting base is 56mmx56mm (from bοlt to bοlt-23 Nema?).
    The label mention only manufacturer and the model of it-Barcrest 340230. I did some google searge but with no luck.
    I want to ask if they are suitable for a home cnc mill project and if so what volt/ampere driver should I look for them.
    I am a newbie in electronics and here in Greece all these informations are hard to find.
    So I would really appreciate any reply.
    Jun 2003
    1365
    Most steppers used for our machines have 200 steps per revolution, and a lot of us use gecko drives wich will put out 10 micro steps per step for a total of 2000.
    Basicly it sounds like those ones probably wont be suitable for this.
    Jon
    Mar 2004
    190
    I am with JFettig, 24 steps/rev is a little rough for cnc
    Fer
    Oct 2004
    26
    Thanks guys!!
    I was afraid so.
    I guess I better start looking for a set of new ones.
  1. Testing stepper motors
    By monkeypuzzle in forum Stepper Motors / Drives
    Last Post: 07-26-2015, 10:38 AM
  2. Stepper Motors and Voltage
    By stuart76 in forum Stepper Motors / Drives
    Last Post: 06-10-2007, 01:29 AM
  3. Stepper motors...
    By Mikael in forum Stepper Motors / Drives
    Last Post: 09-14-2004, 10:41 PM
  4. Rack and pinion and stepper motors
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 05-23-2004, 01:53 AM
