586,094 active members*
4,021 visitors online*
    Jan 2007
    56
    rigi tapping feed speed equasion?
    hello all im getting ready to do some rigid tapping but i cant seem to rember or find the equasion to find the corosponding F (feed) and what the S (rpm )should be t tap with my 1/4 20 thanks for your help ahead of time:rainfro:
    Oct 2008
    13
    I think the formula is F(feed rate)=S(spindle RPM) * Pitch
    Jul 2005
    12177
    Quote Originally Posted by Bikov View Post
    Correct; 20 tpi is 0.05" x rpm; if you use 1000 rpm the feed is 50.0fpm, if you use feed per rev the feed is 0.05 no matter what the rpm.
  1. Speed & Feed
    By kal_pesh in forum Mastercam
    Last Post: 02-23-2008, 08:19 PM
  2. Speed & Feed
    By kal_pesh in forum Uncategorised CAM Discussion
    Last Post: 02-21-2008, 05:15 AM
  3. Spindle Speed for tapping 1/4-20 holes.
    By Loading in forum MetalWork Discussion
    Last Post: 08-17-2006, 03:28 AM
  4. feed and speed / sfm
    By citra in forum MetalWork Discussion
    Last Post: 03-17-2006, 05:55 PM
  5. speed and feed
    By KBW in forum Uncategorised CAM Discussion
    Last Post: 02-21-2004, 04:18 AM
