Can anyone help me?
I'm looking for a detailed drawing of a worktop mitreing jig
I am looking to make one but cannot find a drawing anywhere online..
PDF file attached of what I'm looking for..
Can anyone help me?
Have you found the drawing yet?
Gene
I am after this aswell![]()
The detailed drawing you need is right there in the pdf.
That's a simple item to draw, and they give you the most important DIMS right there in the title, "300mm x 700mm".
Just scan it and import it into your CAD program, scale it to be exactly 300mm x 700mm, and then trace your own drawing on top of it in a different layer.
Shouldn't take more than 5 minutes or so to draw the whole thing once you have it imported and scaled.
Has anyone found a dxf file yet for the jig? The answer below does not work as the 300x700 refers to the worktop size not the jig.
Mac
Done it just needs final calibration
http://danielscnc.webs.com/
being disabled is not a hindrance it gives you attitude
[SIGPIC][/SIGPIC]
I will see what I can do I think I just need to change the file format to a different year it's 2015 ADSK version of dxf.
[SIGPIC][/SIGPIC]
Hi
Hi guys, after searching the web for over a year, I couldn’t find a dxf file anywhere. So I decided to create my own dxf file and after numerous test runs on the cnc and after many
Alterations I finally cracked it, please watch my video
https://youtu.be/iMPfWEFRpWs
If anyone would like the dxf file of my worktop jig
Please like subscribe and comment on the video
That you would like to have the dxf file and I will email you the file, thanks guys
Please head over to our website to get the DXF FILE https://zacels.co.uk/
I would like a copy of the dfx file for your kitchen worktop jig
Hi Zasto
This is great! Thanks a lot for your file - I will find a CNC dude to cut it so I can get started on kitchen worktops...
Just a quick question - trying to find out which size to use for the router...
I´m danish so sometimes I get lost in translation, sorry
Is it correct that I have to use a 35mm routerbit and 3/4 router guide bush?
Best regards,
Kenneth - Copenhagen
Well, To scle drawings in .dwg and .dxf (metric)
Width exactelly 1000mm.
Hi Flashdog,
do you have problem with reading?
Make no mistake between my personality and my attitude.
My personality is who I am. My attitude depends on who you are.
Hello Zasto,
Apologies if I have done something wrong, never used forums before and not sure what to do !
Advise would be appreciated, trying to retrain on a cnc after a life changing accident whilst working as a tree surgeon so even getting my head round using a computer has proved challenging.
Hope you understand my predicament and are still prepared to help.
Regards
