603,378 active members*
2,794 visitors online*
IndustryArena Forum > MetalWorking > Casting Metals > What metal will cast with great detail?
Results 1 to 12 of 12
    Mar 2007
    26
    Hello,
    I am casting hand impressions of a 2 month old baby. I am getting life-like replicas with epoxy and rtv's from alginate molds but I'd really like to use metal. What metal (precious metals included) and process would give a result that wont require polishing? It would be a shame to lose the amazing fingerprint detail.
    Jul 2005
    12177
    Have you heard of lost wax casting? I think that would be the route to go but you would have to do a positive/negative procedure first with epoxy and RTV: Cast an epoxy positive from your alginate mold, then a RTV negative from this and make the wax positive from the RTV. Then the wax is coated with ceramic slurry, dried, baked in an oven to cure the ceramic and melt out the wax and the final metal casting is made in the resulting ceramic mould. You can get amazing detail but whether it would extend down to baby fingerprint whorls is questionable.
    Google 'lost wax casting' and 'investment casting'.
    Jul 2006
    58
    Not sure if any of these would be suitable:
    http://www.hitechalloys.com/hitechalloys_002.htm
    Nov 2008
    lost wax casting..
    Mar 2007
    26
    Yes I am familiar with lost wax/investment casting. The issue Im concerned with is the molten metals ability to to conform to the detail of the mold under gravity only. I think it's surface tension is too great. I am told some bronze alloys expand on cooling but I am yet to try it. I may need to look into forced casting?
    Thanks for the link, I will look into these alloys.
    Jul 2005
    12177
    Quote Originally Posted by Nivea View Post
    .... the molten metals ability to to conform to the detail of the mold under gravity only....
    .... I am told some bronze alloys expand on cooling but I am yet to try it...
    With lost wax/investment casting you increase gravity by using centrifugal casting; used a great deal for jewellery work on both a DIY and business level.
    I have never heard of a bronze alloy that expands on cooling but some of the typemetal alloys do. Typemetal also melts low enough that you can cast in silicone molds I think but you would still need to do the positive/negative steps to get the mold.
    Jul 2006
    1062
    Lost wax was made for this...though usually I try to get rid of the fingerprints
    Keith
    Mar 2005
    214
    Spincasting with pewter can give you the same level of detail as lost wax with less steps too, I've got extensive experience with both. As with all things casting, the process does not guarantee quality, you tend to have to get some bugs worked out of both the process and the operator.
    www.harryhamilldesigns.com
    CAD sculpting and services
    Jul 2005
    12177
    Quote Originally Posted by Harryman View Post
    Spincasting with pewter can give you the same level of detail as lost wax with less steps too, ...
    What do you use for the mold in spincasting?
    Mar 2005
    214
    Vulcanized rubber, either black or silicones are the best. You can also use various RTV rubbers, but they can get pretty pricey and don't last as long.
    There's some sites around showing guys DIYing machines and vulcanizing molds in ovens with C clamps. Like most things, it's best if you have the correct equipment, but you can manage with some garage tech stuff.
    To make a very low, low tech centrifugal casting system, fill a bucket on the end of a rope half way with sand, submerge your mold, pour it and twirl like a madman. Not recommended indoors for obvious reasons and keep the burn kit handy.
    Feb 2004
    466
    Have you thought of a covering the epoxy piece you have in metal by electrolysis?
    You could cover it in nickel, like it is used in money printing. I think there is a Discovery Channel chapter about money printing technologies.
    Konstantin.
    Apr 2005
    149
    Hope This Helps You...
    About any metal you cast will need some degree of finishing. Of course, Gold takes the least. Naturally, the higher the karat, the less finishing. Sterling Silver takes a lot of finishing... but you can "pickle" a silver casting and then use an oxidizer and stay away from a lot of finishing. OR... for silver, you can use an electro polishing technique that will almost make it looked buffed and retain all the detail. Hope this helps.
    Ican.
    PS... Don't forget the castable resins that you POSITIVELY cannot tell from real metals until picking them up... and then sometimes it's hard... and the clay metals that you can push into a mold then cure. I'm gonna write a book!!! Ha!
    Hello,
  1. Fanuc OM-PMC to PC cable detail
    By dinesh in forum Fanuc
    Last Post: 10-30-2010, 05:17 AM
  2. Fabrication Drawings With Full Detail
    By weaston in forum Mechanical Calculations/Engineering Design
    Last Post: 08-13-2007, 12:43 PM
  3. Option detail of Fanuc 11t
    By rajesh_1355 in forum Fanuc
    Last Post: 02-17-2007, 04:12 PM
  4. A question of detail
    By dherbman in forum DIY CNC Router Table Machines
    Last Post: 03-03-2004, 10:34 PM
