603,946 active members*
2,643 visitors online*
    Oct 2008
    100
    VB System Failure??
    So I bought a new machine because my laptop was just not powerfull enough.. All set up, ready to go. Loaded mach.. and fired it all up and get nothing.
    It says VB System failure at the bottom field...
    Anyone?
    35494
    Did you reboot after installing, but before starting it the first time? If not, try uninstalling, then reboot, then re-install, then reboot again before starting Mach3.
  1. Dynapath System 10 Monitor Failure
    By nybuxt in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-01-2008, 09:07 AM
  2. bridgport vmc hdd failure
    By jke6113 in forum Bridgeport / Hardinge Mills
    Last Post: 01-15-2008, 11:34 PM
  3. x axis failure
    By Legion99999 in forum Syil Products
    Last Post: 10-26-2007, 08:16 AM
  4. Spindle failure
    By mechanicer in forum DIY CNC Router Table Machines
    Last Post: 11-01-2005, 12:11 AM
  5. Bearing Failure
    By Mr.Chips in forum DIY CNC Router Table Machines
    Last Post: 11-15-2003, 05:03 PM
