586,501 active members*
3,263 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Mach 3 Configuration Steps per unit
    Mar 2008
    28
    Hi, I'm really confuse with this, I read the manuals and the videos but can't solve it.
    1)My lead screw are: 1/2-10 ACME Lead Screw
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=330287884711
    2)Micro step is set to 1/4 in drivers
    3)Motors are NEMA 23
    4)The motor is are directly coupled to the lead screw
    which "Steps per" I should use in mach 3?
    Should I use Inches instead of mm in the "Default Units" becasue of my setup?
    Many Thanks
    Apr 2006
    3498
    Steps/Unit= 200 *4*10=8000 steps/unit
    Dec 2004
    1865
    Post Steps/per unit calculations.
    Quote Originally Posted by andycorleone View Post
    Many Thanks
    Asuming a 200step per rev motor.
    10tpi x 200 step per rev of the motor = 2000full steps/inch. x 4 (1/4 steps) = 8000 1/4steps/inch.
    divided by 25.4 mm/inch = 314.96062992125984251968503937008 steps/mm
    If my math is right, and I am sure somebody will correct me if I am wrong.
    There is also a utility in Mach3 that says input a distance and then measure how far it actually went. It calculates the proper steps for you. It is under one of the set up tabs but I can't remember which at the moment.
    Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
    Mar 2008
    28
    Thanks look like it works I did a circle test with 8000 and measured and to me is perfect.
    Many thanks
    Mar 2008
    3655
    Very good! Now you need to measure the ACTUAL axis travel vs the travel that Mach indicates. If these are not equal, (due to mechanical inaccuracies) then you will need to tweak the steps up or down slightly. UP if distance traveled is LESS than indicated, DOWN if distance is MORE.
    CR.
  1. Steps Per Unit” in “Axis Calibration Problem
    By Mr.Chips in forum Mach Mill
    Last Post: 09-03-2008, 02:45 AM
  2. Mach3 Steps per Unit (Belt transmission)
    By vdKroon in forum Mach Software (ArtSoft software)
    Last Post: 02-18-2007, 11:42 PM
  3. Steps per unit is all messed up???
    By mwalach in forum Mach Mill
    Last Post: 02-18-2007, 06:50 PM
  4. Set-up / Steps per Unit / Threads per Inch
    By adda in forum Mastercam
    Last Post: 01-15-2007, 11:29 PM
  5. Taig MicroMill 2000 and Mach 2, Steps/Unit??
    By JV11 in forum Mach Software (ArtSoft software)
    Last Post: 09-26-2006, 03:32 AM
