603,392 active members*
3,237 visitors online*
    Jan 2008
    4
    BDMS (BMS) equivalent in US?
    Bright Drawn Mild Steel (BDMS) or more normally BMS is used extensively in the UK, and some other former affiliated countries.
    Bright steel bars are carbon steel which has had the surface condition improved over the hot rolled finish supplied by the steel mill. Advantages achieved include improved machinability, enhancement of physical and mechanical properties and improved dimensional tolerances and straightness.
    It is a staple of the model engineering community in many countries but does not appear to be available through the suppliers who deal with small shops in the US. Is there in fact an equivalent or can anyone suggest an alternative.
    BernardR
    May 2007
    781
    Drill rod, comes in many different alloys S7, A2, O1 etc. but if you get it from the cheaper suppliers you may not know what it is. It is centerless ground but you have to watch it I have seen some that was egg shaped by over 0.0005".
    Jul 2005
    12177
    Quote Originally Posted by BernardR View Post
    Bright Drawn Mild Steel (BDMS) or more normally BMS is used extensively in the UK, and some other former affiliated countries...
    I Googled it to find the specs; the equivalent in North America is C1018, cold finished (cold rolled) bar.
    It is just low carbon steel, not an alloy steel, drill rod is very different.
    Tolerances on cold finished bar are something like +0.0005" -0.001" or something like that.
    Jan 2008
    4
    Thanks Geoff, I'll give that a try.
  1. Equivalent Thread Chart - Inch to Metric
    By twocik in forum Uncategorised MetalWorking Machines
    Last Post: 07-02-2009, 03:43 AM
  2. Equivalent of Saturable core reacotor for BP series 1
    By servocontroller in forum Bridgeport / Hardinge Mills
    Last Post: 04-12-2007, 05:06 PM
  3. Help: Super X3 equivalent at harborfreight?
    By andrew888 in forum Benchtop Machines
    Last Post: 02-20-2007, 09:08 AM
  4. Looking for a Metric equivalent to ACME threads!
    By widgitmaster in forum Linear and Rotary Motion
    Last Post: 02-11-2007, 03:12 AM
  5. Equivalent servo system of step motor
    By bunalmis in forum Servo Motors / Drives
    Last Post: 11-23-2006, 12:33 AM
