586,103 active members*
2,906 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Converting a Manual Surface Grinder to a CNC
    Nov 2008
    Is it possible to converting a manual traversing surface grinder over to a CNC driven. It seems that most use surface grinders use hydraulics instead of motors? Whats the reason for this? Thanks.
    May 2005
    674
    Hydraulics are used on the X-axis only. The Z and the Y still use leadscrews.
    Is your manual grinder equipped with a leadscrew on the X or a braided cable? Mine is the latter.
    Manual table feed converted to automatic
    Hello Left 4 Dead
    I worked for Harig Products and know I am working out of my home doing technical support for the thousands of Harig customers through out the USA.
    Harig used hydraulics on there x axis for two reasond cost and reliability. On our EZ Surf CNC grinders we also use a hydraulic cylinder with a textron valve and a encoder on the axis so you can program your movements to
    .00001. The cost to convert wouldnt be cost effective. You might try looking for a good used Grinder, if you have any questions on what to buy or where to look may give me a call or e mail me you phone number I would be more than happy to help you. Looking forward to talking with you.
    Jim Seyller
    JDS Technical Support
    P: 847 683 0476
    www.harigtechsupport.com
    [email protected]
  1. Cnc surface grinder for profiling
    By Mike Wood in forum Uncategorised MetalWorking Machines
    Last Post: 04-19-2010, 05:06 PM
  2. How does a surface grinder work.
    By SmoggyTurnip in forum Uncategorised MetalWorking Machines
    Last Post: 02-17-2008, 11:57 PM
  3. Please help! Surface grinder questions.
    By tntmachine in forum Uncategorised MetalWorking Machines
    Last Post: 11-16-2007, 07:54 PM
  4. Surface Grinder
    By gbowne1 in forum Uncategorised MetalWorking Machines
    Last Post: 02-28-2007, 06:28 AM
  5. Surface Grinder
    By itsme in forum Uncategorised MetalWorking Machines
    Last Post: 09-13-2006, 06:28 AM
