603,923 active members*
3,921 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > What's Causing my Power supply to Current Limit?
    Nov 2007
    24
    Hey there,
    This isn't a serious problem really but I'm just curious as to what's causing this.
    I'm using the L297/298 driver with a really small power supply (24V, 0.48 A). Should be getting my actual supply on Monday.
    I just wanted to see if I could power my LJ-II steppers even if it's just very slowly.
    Long story short it wouldn't drive the motor. As soon as the power is applied it seems to current-limit even before I command any steps.
    So my question is what causes the power drain even before any pulses are sent to the stepper? Everything worked fine with a small stepper motor.
    Anybody have any ideas?
    24260
    Easy to tell if it is the power supply, just monitor the voltage, if a linear supply, the voltage would collapse on O.L., on a switching supply it might fold back to zero output.
    Even at holding torque ,at zero rpm the current draw is going to be the rated current of the steppers.
    Al.
    Albert E.
    Nov 2007
    24
    Thanks Al the Man,
    I guess for some reason I was assuming the motor wouldn't draw any current until steps were commanded from the L297.
    I think I need to spend a few more minutes with the datasheet.
    Thanks for your help.
  1. Constant Current power supply, help please
    By oliverthepig in forum CNC Machine Related Electronics
    Last Post: 04-21-2009, 03:01 PM
  2. Steppers, Power Supply, and Current
    By kiltjim in forum Stepper Motors / Drives
    Last Post: 08-23-2007, 02:43 AM
  3. Limiting In-Rush Current - CNC Power Supply
    By snakebit95 in forum CNC Machine Related Electronics
    Last Post: 01-19-2007, 09:21 AM
  4. Gecko power supply 2/3" current rating?
    By JFettig in forum Gecko Drives
    Last Post: 01-06-2005, 03:04 PM
  5. current per phase for power supply?
    By FLUTE HEAD in forum CNC Machine Related Electronics
    Last Post: 07-31-2004, 06:41 PM
