603,960 active members*
2,537 visitors online*
    Mar 2005
    73
    Mazatrol Backlash Adjustment
    Does anyone have a good method for adjusting backlash on a Mazatrol? I seem to remember some sort of method I read about but now I can't find where I read that.
    "Fire is cool" -Beavis
    Jun 2008
    150
    Two moves away, one move back. MDI or program with singleblock or option stop, after the first move, set your indicator, move away then back. Result is mechanical lost motion. Check minimum 3 places along axis and kind of "average to your advantage"
    Lee
    Mitsubishi/Mazaks have two parameters, one is for G0 moves and the other is for G01 moves. Check both ways.
    Mar 2005
    73
    Isn't there a way to calculate the offset value or do you just have to poke around till you get it? Also I know of BLX and BLZ parameters for backlash, but are they for rapid or feed?
    Jun 2008
    150
    Sorry, didn't realize you had the T1 or T2 controller. Those are the backlash parameters for X and Z, both G00 and G01. T32 on had the G00/G01 params.
    Lee
    Dec 2007
    300
    Attached is the official Mazak procedure for mills. Maybe it will help.
    Attached Files Attached Files
  1. Mazak M-4 Mazatrol T2 and mazatrol Cam T2 operating manual in english
    By tuanpq in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-09-2021, 04:06 PM
  2. Circle cutting still have kinks after backlash adjustment.
    By alexccmeister in forum Benchtop Machines
    Last Post: 09-21-2008, 02:38 PM
  3. backlash adjustment
    By Mark Hockett in forum Fadal
    Last Post: 11-15-2006, 02:29 PM
  4. Ez Trak backlash adjustment
    By eman5oh in forum Bridgeport / Hardinge Mills
    Last Post: 12-18-2005, 03:29 AM
  5. Z axis backlash adjustment help sieg x3
    By replicapro in forum Benchtop Machines
    Last Post: 11-07-2004, 07:13 PM
