603,946 active members*
2,224 visitors online*
    Apr 2005
    460
    Unhappy Fanuc 3T programing help
    I'm strugling with a Tsugami chucker with a 3T it is a gang slide type machine
    my hang up is tool offset's I'v been expermiting with it in my spair time and have found what I think is the procedure , after touch off and measure with a given tool assine tool # and offset T0101 for tool 1 offset 1 then G50 XY to the existing value and as long as the program calls the tool and offset # it should repeat I'm having a hard time with the fanuc manual's and what makes it worse I'm use to a manual lathe and all of the examples are for a turit with the tool's on the back of the Z It also preform's G2 And G3 in opposit rotation If any one has a sugestion for a text book with beter programing examples than the factory one I'm All ear's I could also use some info on spindle disasembly I'm going to need to quiet up the bearing's in it and the local dealer diden't seem to be much help Thank's in advance Kevin
    Jul 2006
    8
    tHIS A EXAMPLE OF TURN mAZAK WHIT FANUC 6T DUAL TURRET
    Attached Files Attached Files
  1. CRC programing with an old Fanuc 11M controller
    By Moparmatty in forum G-Code Programing
    Last Post: 10-02-2020, 03:23 PM
  2. Help programing fanuc 0-m
    By PRIOR666 in forum Fanuc
    Last Post: 05-28-2007, 09:22 PM
  3. Fanuc 0M G10 programing
    By Chipload in forum G-Code Programing
    Last Post: 04-11-2007, 03:17 AM
  4. Programing help with fanuc 10T
    By adaptaflex in forum Fanuc
    Last Post: 02-16-2007, 03:11 PM
  5. Acramatic 2100 to Fanuc Series Oi-ma Programing
    By BUD B in forum Uncategorised CAM Discussion
    Last Post: 11-15-2005, 10:38 PM
