603,935 active members*
4,528 visitors online*
    Oct 2008
    5
    KL-B25 or C11g Breakout board?
    I just ordered the KL-B25 Breakout board from Keling, but I'm wondering if I should have gone with the C11g board. The only difference that I can tell is that the C11g has a couple of relays and a charge pump. I don't plan on using the relays, but like the idea of the charge pump. Is this worth the extra $80? Will geckodrives even work with the KL-B25 breakout board?
    I'm using 4 Nema 34 - 640oz steppers with G203v drives.
    Thanks!
    Apr 2008
    62
    I used the C11G in my CNC mill retrofit.
    It has the charge pump, one solid state relay, one mechanical relay and a variable speed control to hook my DC spindle driver to.
    Made sense to me to buy this board instead of trying to add all these features later with additional boards.
    Timothy
  1. On the CNC 4 PC breakout board
    By seanreit in forum Uncategorised MetalWorking Machines
    Last Post: 11-30-2008, 10:10 AM
  2. what USB Breakout Board to by ??
    By dbss in forum CNC Machine Related Electronics
    Last Post: 01-19-2008, 02:54 PM
  3. Is necessary to use a breakout board?
    By rolveram in forum Stepper Motors / Drives
    Last Post: 08-28-2007, 04:28 PM
  4. Breakout board, Relays on board?
    By Cooper in forum Open Source Controller Boards
    Last Post: 06-10-2007, 01:55 AM
  5. Breakout Board
    By ckirchen in forum News Announcements
    Last Post: 06-20-2005, 05:52 PM
