603,940 active members*
2,463 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Open Source Controller Boards > Modernization of the Elm Dc Servo Controller (Russian UHU by Hudognik)
Page 1 of 15 12311
Results 1 to 20 of 284
    Jun 2008
    66
    Continue Subjects http://www.cnczone.com/forums/showthread.php?t=62911 here, as this open project and i hope that who be else joined to modernizations Elm Chan servocontroller.
    Present new variant scheme and code.
    Change:
    - Moved converter RS-232/UART from PCB into DataCable. USB/UART on FT232 - works, but bad. Better use RS232/UART.
    - Added limit move Limit_L & Limit_R. Questioning of their condition through 20ms (for eliminating noise). If Limit are not used, that detail their chain possible not to install. Internal pull-ups resistors to all input are installed software in AtMega.
    - Select type contact (Normally closed or normally open)
    - Input EMERGENCY STOP (E-Stop) - it is actuated one temporarily enable Limit_L & Limit_R to condition “ServoError”.
    - Output “ServoError”. Moves over to condition “ServoError” with simultaneous indication of this condition. Disable thereof conditions through Off-On power, unset on Reset or in ServoTuning push “Stop” or change the mode.
    - Two steps of protection from unbalance of the positions. 1st. - at excess 20 000 steps immediately transition in condition “ServoError” . 2st. - on time - at excess 3 steps are included timer and if in current 15 seconds unbalance will not become less 3 steps, that transition in condition “ServoError”. If for 15 sec. unbalance will become less 3 steps, that timer reset.
    - Sensing the condition encoder possible (as variant) on interruptions from internal comparator. On him and external entities VD2,VD3, R23-R25, R29 is made analog exclusive or (EOR). The differences in work I have not noticed (no high-resolution encoder), but theoretically she better (fast), than with questioning encoder on interruption from Timer0 (12mks).
    - It is actuated WatchDog (period 38ms)
    - Increased reliability of keeping data in EEPROM. For this: record of each parameter from ServoTuning is produced in 3 bytes located in miscellaneous area EEPROM. At power-up are read these 3 bytes, are then compared and if one of them is not others, that is produced rerecording the bad cell. This is repeated for all importances in EEPROM. When loading parameter from EEPROM in ServoTuning are read given only from one area (without checking for equality). After conservation and loading parameter address EEPROM is changed on address not containing data. After these change - I reset EEPROM did not observe.
    I have done 4 variant Source Code: Servo_AtMega_TimerInt - for AtMega8, on Timer, Servo_AtMega_CompInt – for AtMega8, on comparator and such for AtMega88 - Servo_AtMega88_TimerInt and Servo_AtMega88_CompInt. The Code trims with interruptions from Timer0 possible to use as with scheme, which I shown earlier, so and new variant. With interruptions from comparator, only with new variant of the scheme. The Code trim with interruptions from compator I have checked only with AtMega88, with AtMega8 only partly, but guarantee on 95% that she will work.
    When adjusting in ServoTuning importances for Your motor save in zero bank, as started with it.
    Possible ways of the further improvement:
    - Installing the quartz on 24МГц and change the program
    - Use the hardware multiplying (only on AtMega)
    - Change of time of the servo cycle with 1ms on more low importance
    - Development PCB. Since I all change did on PCB, which shown earlier + with additional element with outboard montage.
    Commentary in Source Code in russian language, but if it is necessary can translate one of the SourceCodes (for example).
    Attached Files Attached Files
    Jun 2008
    66
    Video work modified ElmChan Dc Servo Controller http://depositfiles.com/en/files/tse...iles/tseutbpe8
    Jul 2003
    1766
    What supply (motor voltage) are you using in the video? Looks like pretty low voltage.. How high of voltage have you tested?
    thanks
    sam
    Jun 2008
    66
    The First engine usual DC Motor Brush - for test. He on 220V, but I felt from 130V. So maximum velocity on video 2500 RPM, under 220V he quicker.
    The Second motor – servomotor (old – 1975 Y.), is installed on old tool, which I remake. The Engine on 110V, but I shall add a little more 130V (such beside me Power Source was got).
    On tool with encoder 60 lines x 4 = 240 imp/rotation reaches velocities 4500mm/min (161 imp/mm => F=12 075kHz). Above - limit rotation motor.
    Apr 2006
    169
    Thanks for all this great info. I look forward to read more The video was really cool
    :wee::wee::wee:
    :banana::banana::banana:
    Jun 2008
    66
    Quote Originally Posted by hesham morsy View Post
    ...I look forward to read more The video was really cool
    In Russia presently coldly . That You wanted to hear on hot? (flame2)
    Apr 2006
    169
    Dear arisov77 can you give us PCB layout for yore board
    ps : hot hot hot hot hot hot hot hot hot hot hot hot hot hot hot
    That for Russia i m from Egypt the temperature is +20 to +12 and i m freezing
    right now
    One more thing to ask on the Russian board their is a discussion about l298 Version any result ??
    Jun 2008
    66
    Happy New Year!
    PCB for the last scheme I have no, made http://www.cnczone.com/forums/attach...9&d=1223011455, then I added the separate PCB current limit. The rest elements by outboard montage.
    Small discussion on L298 was, here is scheme and PCB. The Author who gave it writes that it worked, but the other person, who repeated it that it does not work. I think there are some errors: signal Dir (F/R) it is necessary on PC3 (26 pin for DIP28), rather then on PD3/INT1 (pin5). For L298 it is necessary pin 6 and pin 11 (Enable) - to +5V. R1, R2 deleted. Pin 5,7 (L298) to pin 15 (OC1A- AtMega8 (DIP28)) and pin 10,12 (L298) to pin 16 (OC1B - AtMega8 (DIP28)). I think the other it is correct. It is necessary to use SourceCode Servo_AtMega_TimerInt. But as there is no there DeadTime it is necessary to add code (for example, which I was offered here cbcb128).
    Apr 2006
    169
    thx man
    Dec 2008
    7
    u don't share the source file of ATmega+l298 drive....can u please share the same.
    Naeem Mughal
    Jan 2009
    19
    Quote Originally Posted by arisov77 View Post
    Happy New Year!
    Hi arisov, is it possible that I can use the following hardware to build a servo with your atmega8 code and servo tuning software?Parts list: an RC servo with the electronics removed (potentiometer not removed),a H-Bridge drive (10A would do for me as of now), USB to RS232 connection etc..,of course an atmega8 dev board.
    Do I need to change the potentiometer with a quadrature encoder (mechanical resistive)?If yes will the code change with the encoder resolution?(what should be the encoder resolution I have to chose for 1024 position resolution)?Also could you please post the hex file and code for atmega8 with L298 motor driver.It will be very helpful
    Please guide me Arisov.And thank you for sharing your project.
    1050
    Arisov nice work - keep it up!
    RGDS
    Irfan
    Jun 2008
    66
    Here is variant AtMega8 + L298 and SourceCode with "Dead-Time"=1 mks.
    I this did not check so do not guarantee work. For initial check possible to use SourceCode Servo_AtMega_TimerInt. With this code must work all. Afterwards you programme SourceCode Servo_Mega8_L298. If that that will not work, write - try to correct.
    Diodes VD1-VD4 better to use UltraFAST or Shottkydiodes.
    Possible this driver on L298 http://www.ikalogic.com/shm_hb_l298.php will better work.
    Feb 2008
    5
    http://www.c-n-c.cz/viewtopic.php?t=2395 :wave:
    http://www.cnczone.com/forums/showth...t=69640&page=2 12-11-2008, 11:42 AM arisov77 . I'm sorry, I do not know English. To answer questions I do not know. (wedge)
    Attached Thumbnails Attached Thumbnails HPIM_5_1.jpg   HPIM_4_1.jpg   HPIM_3_1.jpg
    Jun 2008
    66
    Jozefp thanks for Your variant. I liked it very much.
    In process of the work on CNC machine are discovered and corrected two programme mistakes.
    Here is change.
    1. Magnified time WatchDog before 125ms.
    2. The Changes to program for eliminating the casual transition in mode ServoError.
    Feb 2008
    5
    Smile
    Thank you for your praise. Spasiba.
    Apr 2006
    169
    Спасибо :wave:
    Apr 2005
    26
    Removed LM393?
    Jan 2009
    19
    To control the servo what kind of input is required?(is it step/Dir pulse or a command based input?)
    Also will the code work with the following circuit diagram in the attachment?
    1050
    think the UHU chip can be directly mounted on this schematic? I have a few unused with me which I can use on this board?
    what are the other Mosfets that can be used -
Page 1 of 15 12311
  1. Russian UHU by Hudognik
    By myown in forum UHU Servo Controllers
    Last Post: 12-18-2018, 06:33 AM
  2. New advanced CNC controllers for modernization
    By Jonne in forum News Announcements
    Last Post: 02-11-2011, 12:41 AM
  3. modernization Fanuc system 5
    By pardoel piet in forum Fanuc
    Last Post: 12-12-2010, 02:43 PM
  4. NC-controller for modernization only 850$!!!
    Last Post: 12-15-2009, 11:47 AM
