588,265 active members*
10,133 visitors online*
IndustryArena Forum > CAD Software > Autodesk > AutoCAD LT 9, can it import/export DXF?
    Hi All,
    I have been pulling my hair out trying to find out what new version of AutoCAD can import and export DXF files. I know that AutoCAD 14 could do it but when I read the specifications for purchasing a new seat it doesn't say anywhere what files it can take in and put out.
    Andy
    All versions of AutoCAD can handle .dxf files. Autodesk created the .dxf format.
    Hi Gerry,
    Yes I know that all of the older versions easily handled them. I should have given more info. I am worried about the new tactic of selling software. I am worried that AutoCAD LT V9 doesn't state directly that it can import and export DXF files and that it might be an add on or force you to upgrade to regular AutoCAD.
    So does AutoCAD LT V9 import and export dxf's? I am not going to be dissappointed if I buy the software and it does not let me do that, correct?
    Andy
    It does say "read/write" to past versions of AutoCAD here.
    http://usa.autodesk.com/adsk/servlet...112&id=8446807
    One way to find out for sure is to download the free 30 day trial.
  1. SW 2005 File Import/Export. How do I..?
    By neilw20 in forum Solidworks
    Last Post: 02-01-2009, 05:57 PM
  2. Protel export to Gerber then import to DeskCNC
    By cncisfun in forum Uncategorised CAM Discussion
    Last Post: 12-08-2008, 12:33 PM
  3. DXF Export/Import Issues with CadKey and FastCam/SLS
    By TronCarter in forum Milltronics
    Last Post: 01-21-2008, 11:11 PM
  4. Design Cad 2000 export/import problem
    By Stueck1 in forum Uncategorised CAM Discussion
    Last Post: 12-15-2007, 05:15 AM
  5. Corel Draw x3 Export to dwg - import to ALibre Design - not editable
    By cnc_gary in forum Uncategorised CAD Discussion
    Last Post: 09-29-2007, 04:34 PM
