586,104 active members*
3,371 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > DynaCNC > Tip voltage setting recomendations?
Results 1 to 7 of 7
    Dec 2008
    19
    What would be a good starting point for say a Cutmaster 52 with a 30amp tip cutting 20 gauge mild steel.
    Anyone know of a chart ?
    Want to have it set close for ATHC to work well.
    How about IPM recommendation?
    Dec 2008
    19
    Anyone know a good rule of thumb for settings?
    I ruined a 60 amp tip on one cutout and I'm sure I didn't have the right tip voltage setting for my tip OR material because the torch didn't seem to keep proper distance from metal. Any help?
    Jan 2009
    bueller, anyone?
    KTM abuser
    Dec 2005
    43
    tip volts
    program to cut a 10"+ line at rec. speed set torch rec. height off steel thc off and cut, watch tip volts. This will give a baseline.
    My hypertherm 1000: 60 amp machine
    40a tip 148 volts 22G steel 325 ipm
    fine cut 40a tip 78 volts 20G steel 120 ipm
    Nov 2007
    4
    I use a 20 Amp drag tip with a 20 Amp setting. Drag the tip right on the metal for thin gauge stock. Works for me.
    Dec 2008
    19
    20 amp Thickness
    Up to what thickness? 1/16"? What IPM for 20amp on different gauges?
    Dec 2005
    43
    ip setting
    Quote Originally Posted by Orangejbird View Post
    Go on the therm. site lookup your cutter go into the manual and print out all the settings. I looked they're there.:cheers:
  1. Help..Stuck at relay ext dc voltage missing but dc voltage OK ?
    By Dirky in forum Bridgeport / Hardinge Mills
    Last Post: 05-14-2021, 06:39 PM
  2. recomendations???
    By john matthews in forum Benchtop Machines
    Last Post: 08-09-2008, 08:40 PM
  3. Any Recomendations For CAM software.
    By JMS4287 in forum Uncategorised CAM Discussion
    Last Post: 03-17-2007, 05:09 PM
  4. Need material recomendations
    By fixit3546 in forum Welding Brazing Soldering Sealing
    Last Post: 12-19-2006, 01:49 PM
  5. tooling recomendations
    By CJdave in forum CNC Tooling
    Last Post: 10-23-2006, 08:44 PM
