586,106 active members*
3,109 visitors online*
    Mar 2007
    114
    VF2 Chip Auger
    My chip auger has stopped working and I am trying to fault find it. It seems to be associated with Relay K34 on the main control board and contactor K311. However what are fuses FU2, FU3 and FU4 on the main input/output board for and what rating should they be ?
    Jan 2009
    .5 amps I think. It should be wrote on the I/O just under the fuse block.
  1. Chip auger
    By br1 in forum Haas Mills
    Last Post: 09-11-2008, 03:15 PM
  2. Chip Auger
    By jstucken in forum Haas Mills
    Last Post: 08-04-2008, 09:40 PM
  3. Mini Mill and chip auger
    By gizmo_454 in forum Haas Mills
    Last Post: 03-10-2007, 04:55 PM
  4. Fabrication of chip auger
    By Janos in forum Uncategorised MetalWorking Machines
    Last Post: 01-31-2007, 09:41 PM
  5. Chip auger help
    Last Post: 01-29-2007, 04:40 PM
