586,103 active members*
3,788 visitors online*
Results 1 to 14 of 14
    Nov 2008
    49
    X2 Z-Axis Motor Mount
    I was just wondering what you perfer? I see some that are directly over top of the ball screw, and some that are off to the side and drive the ball screw via pulley/belt. What is the Pros/Cons of each?
    Thanks, Scott
    Feb 2006
    7063
    Quote Originally Posted by SSfab View Post
    Thanks, Scott
    I took a different approach, very similar to the X3. I securely bolted plates to both sides of the head that extend behind the column. I mounted the screw in the center rear of the column. Worked beautifully, and was very simple to do. Keeps the screw protected from chips and coolant, and doesn't make the mill 5 feet tall.
    Regards,
    Ray L.
    Mar 2008
    3655
    Quote Originally Posted by HimyKabibble View Post
    Regards,
    Ray L.
    Pics please.
    CR.
    Nov 2008
    49
    yeah definatly pics, i think i understand what your saying but lets see some photos.
    Aug 2008
    27
    Sounds like a version of cncbridges Z axis.
    http://www.cnczone.com/forums/showpo...&postcount=293
    Nov 2008
    49
    not a big fan of that. It looks out of place.
    Feb 2006
    7063
    Quote Originally Posted by Crevice Reamer View Post
    Pics please.
    CR.
    I'll have to dig it out and take some. The machine has been in the corner for the last couple of years, since I got a knee mill. Like I said, it's very similar to an X3. In fact, I used an X3 Z axis leadscrew and nut. The motor is mounted to a small plate on top of the column, with a 2.5:1 belt reducer, so the height of the machine is unchanged.
    Regards,
    Ray L.
    Nov 2007
    118
    The way i will do mine when im feeling better. Is ball screw front center,Stepper motor mounted in the back of column. And use pulley/timing belt system.
    And to protect ball screw i will use the samething that protects the table screws on a X2. You can order this rubber from little machine shop.com
    I did think about having the ball screw back center column. But i feel it was not for me;since im doing other mods to it. As for side mount acme or ball screws? I just don't like side loading the dovetails.
    Nov 2008
    49
    Is there anything wrong with mounting it directly over the ball screw, front center?
    Feb 2006
    7063
    Here are the picture of my X2. It's ugly (I did it in a day with scrap material), and dirty (the machine's been in the corner gathering dust for over a year, since I got a knee mill), but works very nicely.
    Regards,
    Ray L.
    Attached Thumbnails Attached Thumbnails P1040777.jpg   P1040774.jpg   P1040775.JPG   P1040776.jpg
    Nov 2008
    49
    not bad
    Sep 2006
    607
    That looks quite nice actually. Could use a caring hand though. Why not sell it?
    Feb 2006
    7063
    Quote Originally Posted by The Blight View Post
    The hassles of shipping. Not likely to find a buyer locally, as I live in the sticks. One of these days, I'm going to get energetic, and resurrect it, to use as a drill press.
    Regards,
    Ray L.
    Mar 2008
    220
    Thanks for the pics, that's what I hope to do eventually. I want my ball screw on the back to keep it away from all the chips. Just makes sense to me.
    Regards,
    Ray L.
  1. Taig Motor Mount
    By sprinter in forum Taig Mills / Lathes
    Last Post: 12-24-2008, 10:06 AM
  2. CNCFusion X3 axis engraving on Y motor mount
    By wisp in forum News Announcements
    Last Post: 03-20-2008, 08:56 PM
  3. Jet JMD-15 Y axis DRO Mount
    By tkoden in forum Benchtop Machines
    Last Post: 02-15-2008, 01:36 AM
  4. Need help to create a motor mount
    By veegaa in forum Hobby Discussion
    Last Post: 12-10-2007, 10:27 AM
  5. Motor mount plans?
    By wilfreeman in forum Benchtop Machines
    Last Post: 01-25-2006, 06:43 PM
