586,296 active members*
4,193 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Hitachi Seiki Service and Support!!!!!!!!1
Page 9 of 11 7891011
Results 161 to 180 of 208
  1. #161
    Feb 2016
    17
    Re: Hitachi Seiki Service and Support!!!!!!!!1
    Hello,
    I have the machine hitachi seiki VK 55II with seico 10 control. and now I can't reset the alarm [742] Editing the program. Does any one know how to fix this alarm. I need your helps.
    Thank you!
  2. #162
    Jun 2015
    42
    Quote Originally Posted by riotmfg View Post
    Any idea where these thermal overloads are? I have looked everywhere, reset all breakers I could find but am still getting the AL-3 Thermal Alarm.
    I managed to clear the lube alarm by cleaning up the sensor in the lube reservoir. PLEASE help, I need to get this thing running.
    -Madison
    I dont usually do a necroposting, but in my case - all thermal overlaod alarms were due broken fan at the back of the control panel
  3. #163
    Sep 2009
    68
    Re: Hitachi Man
    Hi!
    We have a big problem on a machine HITACHI SEIKI VM40 with SEICOS M2 control, year 1988, SN No:40309,
    the machine was working just fine until the battery alarm appeared on the screen 033 BATTERY ALARM
    the both batteries were changed while the machine was powered off (unfortunately big mistake)
    on the screen we had:
    at first BUBBLE READ
    and then after a few seconds
    PC NOT READY
    SEICOS
    mark 2
    when we press NC/PC and then IINPUT the messages on the screen are:
    SUM CHECK ERROR SEQUENCER NOT READY
    BATTERY ALARM PLEASE CHANGE
    We found some procedure for overcoming this status on the machine
    the procedure that we conduct it is:
    1. Press F1(SEQUENCE) ->Press F2(DATASET) -> Press F4(TABLE) -> You will see “Constance Byte Table 1
    2. Type 0 0 (in the 1. 00) -> Press INPUT -> You will see Parameter Write Enable SW On ---------------
    3. Turn on WRITE ENABLE SW that is on MICON16-2 board in control panel
    4. Press F6(END). -> You will see Write Enable SW Off
    5. Turn off WRITE ENABLE SW
    6. Press F6(END) -> Press F1(SEQUENCE) ->Press F3(PROGRAM) -> You will see Parameter Write Enable SW On
    7. Turn on WRITE ENABLE SW that is on MICON16-2 board in control panel
    8. You will see top line of ladder automatically
    9. Press F2(ALTER) -> You will see ___(Cursor) on screen.
    10. Press F4(STORE) -> Press INPUT.
    11. Press F6(END) -> You will see Write Enable SW Off
    12. Turn off WRITE ENABLE SW
    13. Turn off NC power -> Turn on NC power
    After we did the procedure, we turn on the machine and we get Z80 CPU ALARM on the screen any suggestions how to continue from here?!?!
    We are asking a confirmation did we apply the right procedure?
    and after this we are assuming that the parameters should be loaded
    we have a backup of the original parameters,
    but if we need to load anything else please advise,
    If this is not the right procedure please let us know
    and point us for the right procedure in step by step if possible,
    We don't have any experience with this machine or this control so any suggestion is more than welcome,
    Thank you all in advance,
    Regards,
  4. #164
    Jan 2018
    i need electric drawing hitachi seiki va 45 fanuc 11m can you help me
  5. #165
    Sep 2014
    6
    Quote Originally Posted by sedi66 View Post
    Dear friends
    I need operation manual, wiring diagram, for a 5NE-1100 hitachi seiki lathe 1980 with fanuc 6T control
    thanks
  6. #166
    Quote Originally Posted by Hitachi_man View Post
    Hello all out there lost in the confusion of trying to find support for your Hitachi Seiki machines. I own a CNC Service Company in Wichita Kansas working on all brands of machines, but specializing in Hitachi Seiki. I currently have over 10 gig of info on Hitachi Seiki machines in my database from machine software to procedures and ELECTRICAL MANUALS!!!!! I have years of experience working with these machines, and until June of 04 I worked for Mori Seiki in LA as the Hitachi Seiki specialist. We DO travel, and my hourly rate for shop labor is only $75.00 per hour no matter what state your in. I also do phone support and provide procedures at $45.00 per hour 1 hour min....If you have a Hitachi Seiki machine, other machine models welcome also, call us and we will be happy to help!!! (cureing your headaches is free!!)
    You can contact us at 316-744-0549 just ask for Josh, aka Hitachi_man
    well be looking forward to hearing from you!!!
    HELLO
    I looking for DOCUMENTATION CS20/25 SEIKOS 21i TA (with motor and BETA DRIVE TURRET) with alarm 1020. Regards
  7. #167
    Aug 2007
    138
    Re: Hitachi Man
    vladimir, you have lost the ladder program for your mill. PM me and I will email instructions
    Keshka
  8. #168
    Apr 2006
    113
    I have 1986-87 Hitachi-Seiki HT-20 Fanuc 10TE control cnc lathe. It was setting for a couple of months. went to hook it up and it boots up to ram test then stops and goes no further.... any suggestions?
    Jim Compton
    Visit www.manuals-depot.com Many tractor manuals available
  9. #169
    Dec 2009
    539
    Hi Jim
    you might need to regen if it lost battery / data - you can pm me your email and Ill reach out to get you going
    John
  10. #170
    Nov 2019
    Hi Josh, I have an HT23J. The tool unclamp/clamp piston hit the hydraulic tool release piston while the turret was indexing, & stopped the turret. I don’t know how to get it back to zero. Can you help me with the procedure to zero it?
    Its a Hitachi-Seiki HT23J with a Yasnak control.
    Thank you
    Mike
    [email protected]
  11. #171
    Dec 2009
    539
    Mike
    I sent you an email, take a look. As long as nothing broke it should be a quick fix
    John
    Quote Originally Posted by greelyman View Post
    Thank you
    Mike
    [email protected]
  12. #172
    Aug 2012
    65
    Good Day
    Please can anybody help me with the datasheet for a Hitachi Seiki VA-40 Micon 8 system? All data was lost due to low battery.
    I am situated in South Africa. You can email me, [email protected].
    Any help will be appreciated and thank you in advance.
    Jaco
  13. #173
    Apr 2007
    13
    Dear friends,
    How to set zero return procedure on Hitachi Seiki VM 40II,seicos 3?
    Thank You,Have a nice day
    Rizal
  14. #174
    Dec 2009
    539
    Hello
    what do you mean? Did you lose data and now it is not going home but oevertravelling?
  15. #175
    Apr 2007
    13
    After SPHC card has changed,now the machine always overtravell when zero return performed
    Thanks for your attention Mr John
  16. #176
    Aug 2020
    Hi All
    I have hitachi seiki st200, Seicos Pcflexi control.
    Alarm 700044 EMG-STOP pressed. DB2. DBX185.4
    Su--
  17. #177
    Jan 2021
    13
    Hi Hitachi_man
    I have hitachi seiki vk45 vmc Ladder corrupted,No pack up and no YU YU software can you please help me
  18. #178
    Jan 2021
    13
    Hi
  19. #179
    Dec 2009
    539
    Quote Originally Posted by Austrik View Post
    Hi
    Hello
    Send me a PM with your email and I will help you
    John
  20. #180
    Jun 2013
    I have just got a old Hitachi VM40 with siecos mark II controller. When i power up the machine, i got alarm "battery alarm ---- please change", i change the battery when machine power up, but i can reset this alarm. Can someone help me???
  1. Did Mori Seiki Buy Hitachi Seiki?
    By Billet Sean in forum Mori Seiki lathes
    Last Post: 05-05-2011, 04:12 AM
  2. Hitachi Seiki Parts, Support and Manuals
    By npkaye in forum News Announcements
    Last Post: 03-09-2011, 12:16 PM
  3. HITACHI SEIKI MACHINES. SERVICE / TECH
    By bob1112 in forum Uncategorised MetalWorking Machines
    Last Post: 09-14-2010, 04:49 PM
  4. Hitachi Seiki tech network - support
    Last Post: 12-29-2008, 10:26 PM
