Ive been playing with this for two days and have not found a solution nor have I found anyone that has had the same problem. I have recently installed X3 (clean install with no migration used) and then X3 mu1. I installed this fresh and clean so that my X2 install wouldnt affect X3 at all.
I am using Mill Default.mmd , Default.control, and mpfan.pst all from the initial install. I am using the default tool libraries with the default material. I have my Tools set to use "from material" for speeds and feeds. (In X2 I have created several tool libraries and material libraries that I would like to be able to pull in to X3. I have hours and hours of time invested in created these libraries.
The problem I am having, is when I try to create any tool path, pull in a tool from a tool library, right click to pull up the speeds and feeds calculator. I adjust the percentages to my liking, hit the <update> button to update the tool. Even if I hit the <calculate speed/feed> button when I close it out to go back to the parameters page none of the changes that I have made to the tool through the <update> have been saved. The plunge and retract rates are completely disregarded and 50% of the tools feed rate is entered in the boxes instead. If I turn the coolant on, it is not saved and turns back off. The only way I can get the changes to stick is to use <from tool> for the speeds and feeds setting and manually edit the tool parameters in the part file.
While this is a work around for me now, this makes my tool and material libraries useless along with the speeds and feeds calculator in X3. Has anyone else noticed this problem and what can I do to get this resolved?
Thanks.
