603,370 active members*
3,875 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Need to make some stamps. Recommendations for material
    Apr 2004
    354
    I need to make about a dozen stamps with some small lettering on them to stamp into 316 stainless. Any recommendations for material type and heat treatment?
    Aug 2007
    34
    01 tool steel will work as it is easily machined and will hold a sharp edge. You can torch harden and quench in oil for a small run. If you need these stamps for long use, consider A2 air hard or M2, both of which you will probably have to send out for heat treat.
  1. CAM recommendations
    By Matt_NH in forum Uncategorised CAM Discussion
    Last Post: 02-23-2008, 07:42 PM
  2. Question about Raised 3d Lettering Stamps
    By ROBTRONIX in forum Uncategorised CAM Discussion
    Last Post: 09-11-2006, 04:47 PM
  3. VFD recommendations?
    By split63 in forum Uncategorised MetalWorking Machines
    Last Post: 05-27-2006, 10:39 AM
  4. Stamps
    By dighsx in forum Vectric
    Last Post: 05-14-2006, 06:41 PM
