603,358 active members*
3,917 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Taig Mills / Lathes > Taig mill bottom base mounting bolt hole spacing pattern
    Jun 2008
    1082
    Does anyone know what the spacing is for the mounting bolts on the bottom of a Taig mill?
    I searched Google and cnczone.com with every term I could come up with to find this for myself but haven't had any luck. I also tried to measure it myself, but I don't really know how to take these kinds of measurements accurately.
    Here's the best I could get by measuring by hand...
    Attached Thumbnails Attached Thumbnails Screenshot - 1_17_2009 , 3_50_25 PM.png
    Nov 2007
    981
    I would just email Taig themselves or Nick Carter.
    I'm sure one of them will help-
    Dave
    Dave->..
    Jun 2008
    1082
    That sounds like a good idea, thanks. I sent an e-mail to Nick.
    I'll fix the image above when I get the correct measurements...
    Jun 2008
    1082
    I called Taig. It looks like there isn't specific spacing for the holes on the bottom, each mill may be different.
    I also e-mailed Nick, here's part of his reply...
    What I do is drill for the middle front bolt, and bolt the mill to the base, then use a transfer punch/sharpie to mark the two other holes, then remove the mill and drill for them.
    Nov 2007
    981
    Interesting, thanks for passing on the info-
    Dave
    Dave->..
  1. Circle With Bolt hole Pattern
    By JJsFab in forum Torchmate
    Last Post: 09-01-2013, 06:07 PM
  2. programming bolt hole pattern
    By jrogus in forum CNC Machining Centers
    Last Post: 05-23-2008, 07:23 PM
  3. Bolt hole pattern with only a drill press
    By sanddrag in forum MetalWork Discussion
    Last Post: 05-04-2006, 07:41 PM
  4. Bolt hole spacing on a flange
    By Bill Wann in forum Autodesk
    Last Post: 03-15-2006, 02:11 PM
  5. Lining up a CNC mill to an existing bolt pattern?
    By youngfg in forum MetalWork Discussion
    Last Post: 11-07-2005, 09:05 PM
