603,371 active members*
4,452 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > OPTIMUM BF20L mill, z-travel exactly from table height ?
    Dec 2005
    315
    Hi..
    The OPTIMUM BF20L has a z-travel of 280 mm.
    http://www.optimum-machines.com/prod...rio/index.html
    How is this exactly calculated ?
    If the drill-cutter head is down, does it touch the table ?
    Suppose a cutter sticks 100 mm out of the cutter holder.
    Does the distance between the cutter and the table then become 280 - 100 = 180 mm ?
    Or will it be a little bit more then 180 mm ?
    How much more ?
    Thanks..
    Vroemm.
    Jun 2007
    56
    On my Weiss machine, pretty much the same as the Optimum, the spindle taper nose is 30mm above the table when fully wound down and 330mm above when fully wound up.
  1. Optimum BF20L CNC conversion
    By JanHenning in forum Vertical Mill, Lathe Project Log
    Last Post: 03-11-2009, 05:09 PM
  2. X2 with stiff table travel?
    By isaac338 in forum Benchtop Machines
    Last Post: 09-25-2008, 03:21 PM
  3. OPTIMUM BF 20 Vario Mill Made in Germany
    By gcamlibel in forum Uncategorised MetalWorking Machines
    Last Post: 02-03-2008, 03:01 PM
  4. What's the max table and head travel on your X3 mill?
    By JMcDonald in forum Benchtop Machines
    Last Post: 12-21-2007, 07:36 AM
  5. Ideal table height for a mill
    By ranchak in forum Uncategorised MetalWorking Machines
    Last Post: 11-20-2007, 08:19 PM
