Today has been released the Beta 2 of devCad Cam Pro application, see http://www.devcad.com
Here is a brief list of the added features of the Cam version of
devCad (for the Cad feature you can see www.devcad.com)
Main features:
Tool database with full management, with tool shape preview
Management of Cam project, like a collection of objects to machine e
toolpaths
The import of the objects is done from the Cad part of the
application, where you have full access to all the advanced 2D cad
functions.
During the import job all TrueType text are converted to regions, so
that you can machine then immediately
In the Cam graphic View you the objects can be:
- copy&pasted
- rotated
- moved
- mirrored
- scaled
- deleted
with snap and object snap fetaures
You have printing and printing preview features, with tiling
Toolpath types:
- Profiling with automatical computation of offset and side
- Area clearance, raster or offset (like ArtCam Insignia)
- Machine along vector
- Drilling
You can apply a Pre Drilling automatic Path to all these jobs, simply
enable it and select the right Tool, all the paths will be created
automatically
Every job is applied as a serie of toolpaths at incremented Path,
according to the StepDow parameter of the selected Tool
You can apply associative Bridges to object, used in Profiling
toolpath.
Bridges can be created automatically according several strategies, or
manually with editing functions
Bridges have lenght and height parameters
By Drag&Drop on a Treeview panel you can modify on the fly the order
of Toolpaths, element inside the single toolpath, apply automatical
sorting according to several strategies and so on.
Al the actions have an infinite Undo-Redo feature
You can then export to a 3D DXF, with a layer for every Toolpath and
different colors for Rapid Moves, Working paths and GoHome
You can create GCode or similar files using a post processing file
fully compatible with the .con file of ArtCam Insignia
thank your for your attenction
the devCad team
