603,355 active members*
3,949 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Bolt hole pattern for Fanuc 18i
    Jan 2009
    Im wondering if anyone can provide a sample program to do a bolt hole pattern in a fanuc18i controller. I think i should be using a g72.1, but i cannot figure how to use it. I just get an alarm everytime i try it. Please Help
    Feb 2006
    992
    Check your machine parameter manual, then turn it on otherwise I believe it an option you have to order.
    The best way to learn is trial error.
  1. Circle With Bolt hole Pattern
    By JJsFab in forum Torchmate
    Last Post: 09-01-2013, 06:07 PM
  2. Taig mill bottom base mounting bolt hole spacing pattern
    By Hirudin in forum Taig Mills / Lathes
    Last Post: 01-20-2009, 09:42 PM
  3. programming bolt hole pattern
    By jrogus in forum CNC Machining Centers
    Last Post: 05-23-2008, 07:23 PM
  4. Fanuc bolt hole macro
    By Machinist3 in forum G-Code Programing
    Last Post: 05-23-2008, 04:43 PM
  5. Bolt hole pattern with only a drill press
    By sanddrag in forum MetalWork Discussion
    Last Post: 05-04-2006, 07:41 PM
