586,075 active members*
4,014 visitors online*
Results 1 to 8 of 8
    Feb 2006
    52
    Angle Iron Deflection ?
    Hi working on new gantry router design and intended to use 3"x3"x10'
    1/4" angle iron spanning 8-10ft between support legs and predict a load
    of approx 100lbs. I am concerned with deflection or twist. if secured
    to supports diff and or where my load rides on the angle iron would change
    the amount of deflection. If I uploaded pic properly it might give an idea of
    what I am trying to do.
    Thanks Gads
    Jan 2008
    48
    What accuracy are you looking for. 100 lb on a pair of 10ft L beams is enough to induce noticeable flex. The math for these is simple if you know what you are doing. If not there are some good tables for moment of inertia as well as cantilever beam calculators online. Accurate prediction of deflection is possible, the hard part is determining what is allowable.
    Aug 2007
    147
    Hey Gads,
    A 3x3x0.25 has a moment of inertia of 1.24 inch^4 in both directions (Ix and Iy).
    E = modulus of elasticity for steel = 30,000,000 psi
    To calculate the max deflection over 10 feet (force concetrated at the center)
    = W * length³ / (192 E*I)
    = 100lbs * (120 in)³ / (192 * 30,000,000 * 1.24)
    = 0.0242"
    If the 100 lbs of force is distributed over two pieces of angle, moment of inertia I is doubled and the deflection is cut in half. Still quite a bit deflection at around 0.012".
    Nov 2007
    197
    I was thinking about this same thing the other day - any good websites on how to learn these calculations?
    Gads, Hope you don't mind that i ask a question in your thread:
    How does the cross section of the design effect the inputs?
    for example I'm looking to use something like the following
    2.6" legs, 8" wide. 1/2" thick - 60" long
    May 2005
    925
    Quote Originally Posted by multiplex View Post
    For these google UPN beam or UPN steel channel, and go from what you find there, Im sure you will get good info.
    Pablo
    Feb 2007
    Try these links for calculations... the sites also provide material properties and explanations in varying details for those with less experience with the equations.
    engineersedge http://www.engineersedge.com/calculators.htm
    efunda http://www.efunda.com/home.cfm
    Sep 2006
    Try the freeware "BeamBoy" program. It's great for quickly doing this type of analysis.
    May 2006
    22
    Unless your angle is loaded through the 'Shear Centre', it will twist as well as deflect vertically. The amount will depend on how the ends of the angle are supported at the ends - 'simple' or 'encastre', or something in between! You really need to have a chat to an engineer friend, if you have one!
  1. angle iron & flat bar comb tool
    By anil in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 09-29-2007, 07:13 AM
  2. 45 degree bevel on angle iron
    By Rypper in forum DIY CNC Router Table Machines
    Last Post: 11-14-2006, 07:00 AM
  3. Vgroove and angle iron router
    By denzil in forum DIY CNC Router Table Machines
    Last Post: 10-21-2006, 08:44 PM
  4. machining angle iron
    By stymye in forum MetalWork Discussion
    Last Post: 09-04-2006, 06:43 AM
  5. Cleaning up angle iron edge
    By Mark Van in forum MetalWork Discussion
    Last Post: 11-16-2005, 11:20 PM
