Spindle is locked in the wrong position at tool change. is there a parameter for indexing spindle to correct position?
try parameter 6577, increase or decrease the value it should work.
if machine run into wrong position again, you should check the timing belt or the spindle belt
Ahn Vuong
if it doesn't work, try prm#6531 (Position coder method orientation stop position)
#6577 is Orientation stop position shift amount
I think both work
