586,094 active members*
4,189 visitors online*
    Jun 2008
    62
    HAAS RS-232 D-Sub Connector
    So I'm looking in the Haas manual, for the RS-232 wiring. It gives me the location og ground PIN-1, but the diagram lists wires as pin 2-red, pin 3-black, pin 7-green, and points to the connector as pins 25, 13, 14. Why dont the pins match wire colors?
    Jun 2008
    62
    Wait, nevermind, I didnt realize I just have to count the pins, and the diagram was showing me the direction they are numbered. OOPS. Still wakin up!
    Jun 2008
    62
    Well then, instead of that question...the manual says connect to serial port 1 to send/receive. I take it the top port is port 1? I cant find it in the manual.
    Jan 2008
    282
    Yes,
    Bottom port is for controlling other equipment
    Lkenney
    Jul 2005
    12177
    Quote Originally Posted by Mic6 View Post
    ...... I cant find it in the manual.
    Sometimes things are difficult to find in the Haas manuals because they are not there. They seem to have slimmed the manual down over the years but you can find a more complete and up to date pdf file on their website. Go to this link and scroll down:
    http://www.haascnc.com/custserv_updates.asp#manualupd
    EDIT: I also found this in their Answerman section:
    http://www.haascnc.com/cncmag/answer...&ArticleID=534
  1. Stepper connector
    By cnczoner in forum CNC Machine Related Electronics
    Last Post: 04-08-2020, 01:36 PM
  2. Anyone recognize this connector?
    By cnczoner in forum Uncategorised MetalWorking Machines
    Last Post: 09-10-2008, 03:34 AM
  3. 10 pin connector help
    By Rees Guitars in forum Controller Cards
    Last Post: 01-20-2008, 07:29 AM
  4. Need connector
    By cncadmin in forum CNC Machine Related Electronics
    Last Post: 03-17-2005, 07:26 PM
  5. 25 pin connector
    By polyhedron12 in forum CNC Machine Related Electronics
    Last Post: 02-23-2005, 11:40 PM
