mastercamx3 ive loaded it on my dell laptop windows vista when i go to make my toolpaths my chaining arrow is not visible on the screen cant find setting please help
What type of graphics card does that laptop have ?
A couple things that could help would be found in Settings, Configuration... Under the Screen tab...
Try checking the disable hardware acceleration and/or the disable front buffer checkboxes...
If that doesn't help then at least if you let us know what the graphics card is somebody else can give more ideas...
Did you also load MU1?
sometimes i cant see the arrow when chaining solids i click the wireframe tab and all is ok.
if you are not chaining a solid then i would listen to the posts above.
2007 Haas TMP-1 Microscribe MX-5 Mastercam X4 Mill Level 3 Surfaces,Solids Seagate 2 tb hard drive AMD 64x2 8gig ram windows ultimate 7 64bit Geoforce 8800 GTX
thank u the hardware deceleration worked thanks again
im new to this forum and its great!!!!
