586,094 active members*
3,706 visitors online*
    Vacuum pumps off ebay
    Hello,
    Been thinking of adding a vacuum table to attach parts to my cnc mill. I will make fixtures that fit the outline of the part, and hold it in the x/y plane, and will rely on the vacuum to hold it down.
    I do small modifications to a large number of parts, so I would like to do this to cut down on the time I use to fix them to the table.
    I have found some pumps on Ebay. The one I think look best at the moment is 013-2. A link to more info is here: http://www.sh-vacuum.com.tw/stokes/1.1.htm
    Anyone think this is a good idea? What specs should I look for?
    Jan
    Oct 2007
    61
    Apr 2007
    64
    We have Gast vacuums where I work!
    http://www.gastmfg.com/pdf/rotvane/23_series.pdf
  1. vacuum tables and pumps
    By cabnet636 in forum Camaster
    Last Post: 08-24-2015, 12:29 AM
  2. Coolant Pumps
    By thetrillionaire in forum Haas Mills
    Last Post: 03-25-2008, 02:40 AM
  3. Trouble with replacement lube pumps
    By M_Controls in forum Milltronics
    Last Post: 09-20-2007, 03:28 PM
  4. cheap vacuum pump (10 hp) on ebay
    By sawmiller in forum Work Fixtures / Hold-Down Solutions
    Last Post: 08-13-2007, 11:23 PM
  5. Found surplus pumps for vacuum forming
    By kayaker43 in forum Vacuum forming, Thermoforming etc
    Last Post: 06-13-2007, 05:53 PM
