586,119 active members*
3,420 visitors online*
Results 1 to 6 of 6
    Jun 2006
    66
    solenoid valve for atc
    Can anyone tell me if I can use a 12 volt 3 way 2 position single solenoid valve to operate a spring return air cylinder for an auto tool changer (following the great "Hoss" instructions)Or do I have to use 110 volt? I have a Mini IO bob with Vampires.And what solid state relay do I need?
    Any help would be greatly appreciated GED
    Mar 2008
    3655
    Hi ged!
    Why not just use THIS one?
    http://surpluscenter.com/item.asp?UI...00&catname=air
    CR.
    Mar 2008
    3655
    Jun 2006
    66
    12 volt solenoid
    Thanks CR
    I ve already purchased the Bimba air cyl (4 bucks) and the EMC VC82,3 way,2 position 12 v dc solenoid from Princess Auto and I was just hoping I could still use it if I used a 12 volt ac adapter or other 12 volt supply.
    Mar 2008
    3655
    Quote Originally Posted by ged View Post
    Thanks CR
    Sure, if you already have it, why not? As long as it turns the air on and off. But the DC relay only handles AC, so you will have to relay your primary 120AC Voltage to the 12V PSU.
    Seems overly complex to me. I would just buy the 120V solonoid and have fewer connections to fail.
    CR.
    Jun 2006
    66
    solenoid
    Thanks for your help CR I think Ill take this one back and get the right one
  1. Tire Valve / Shraeder Valve Dimensions
    By jamiedaugherty in forum Mechanical Calculations/Engineering Design
    Last Post: 01-22-2010, 04:46 PM
  2. Solenoid
    By jorgehrr in forum Servo Motors / Drives
    Last Post: 08-04-2008, 05:22 PM
  3. series II interact II 24vdc solenoid valve
    By bigtoad170 in forum Bridgeport / Hardinge Mills
    Last Post: 12-13-2007, 09:17 PM
  4. Oxygen Pierce solenoid Valve
    By roady89 in forum Waterjet General Topics
    Last Post: 10-05-2007, 11:11 PM
  5. solenoid help
    By jimini in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 02-13-2007, 07:15 AM
