587,172 active members*
3,161 visitors online*
    Sep 2008
    73
    input filter emi/rf
    Hi
    I have a 220 volt single phase 1.5KW vfd running a 3 phase 2 hp motor. My question on buying a input filter (emi/rf). What amperage should I use??? A 10amp should be ok??
    Evan
    24223
    If I was just fitting one, I would fit it to the motor side, the VFD manufactures and some transformer suppliers make them, 3 phase chokes.
    Al.
    Albert E.
    Sep 2008
    73
    :confused:
    Hi Al
    So don't use a input filter at all? I was going to choke and twist the wires on the ouput and put a emi/rf filter on the input.
    So I am really confused.
    Maybe I will start at the beginning. What kind of filter (input, output or both) should I use. This is going on a cnc milling machine conversion.
    Evan
    24223
    Page 13 of this shows all the options of suppression, http://www.ctiautomation.net/PDF/Hit...VFD-Drives.pdf it all depends on what you are aiming for, For the VFD's I have used, the majority I have never used any suppression, in a couple of cases I did use 3 phase choke on the input and output.
    The choke between the VFD & motor is considered more for reducing stress on the motor and VFD.
    Al.
    Albert E.
    Sep 2008
    73
    Thank you very much Al for all of your time.
    Evan
  1. Air filter for controller box
    By cncuser1 in forum CNC Machine Related Electronics
    Last Post: 09-01-2008, 12:07 AM
  2. Changing the Coolant Through Filter
    By donl517 in forum Fadal
    Last Post: 09-18-2007, 11:31 PM
  3. Filter Question
    By totalfab06 in forum Waterjet General Topics
    Last Post: 03-10-2007, 02:02 AM
  4. arc and nurb filter
    By camtd in forum Surfcam
    Last Post: 07-25-2006, 01:48 PM
  5. Self cleaning Filter
    By Rance in forum DIY CNC Router Table Machines
    Last Post: 01-18-2006, 06:58 PM
