586,724 active members*
3,795 visitors online*
    56
    Wing cutting and 4 axis g-code
    I want to use g-code to run my 4 axis foam cutter. I am interested in controlling all four axis for cutting wings etc...each axis moves at its own speed and direction.
    Now, I have seen the stuff for cutting signs and stuff like that. That is not too difficult.
    I am interested in accomplishing what the Guilles Mueller software does, but with g-code or something similar. I need to cut tapered wing cores, and as such each axis moves at its own speed and direction. Then I can use rapids for foam blocking and other functions, and then slow back down and cut the wing.
    Does that make sense?
    Any ideas?
    Feb 2006
    17
    reply
    hi THend,
    for my little experience DeskCNC is the only software that use the 4 axis Gcode because when you generate a file he's work with X-Y and U-V.
    on the market there are many CAM that work for the EDM machine but it's to difficult to obtain a correct g-code easly.
    DeskCNC is very easy to use and can work also with router
    sorry for my english
    bye
    Jul 2003
    36
    Profili has just added CNC foam cutting with G-code output.
    Sep 2003
    1113
    Thought about Excel?
    Not the g-code solution you are looking for - but should do tapered cores.
    A fellow in Johor Baru, Malaysia wrote some free software that plugs into Excel 2003. Its VB based as I recall.
    A search of the cnczone outta turn it up if you're interested. He also has some 6 axis source code.
    Cheers - Jim
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
    Apr 2009
    109
    Check out my CNC hot wire foam cutter. It is controlled with CNC USB motion controller which directly supports Profili generated 4-axis g-code.
  1. ExcelCut 4 Axis Wing Cutter with Source Code
    By arman in forum CNC Wire Foam Cutter Machines
    Last Post: 03-22-2018, 07:14 PM
  2. cutting circles.....and G code
    By greenene in forum Uncategorised CAM Discussion
    Last Post: 06-17-2008, 11:09 AM
  3. Look at this code for cutting threads
    By jjenks in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-25-2007, 06:06 PM
  4. will you cut wing ribs for me ?
    By FADMUKER in forum Employment Opportunity
    Last Post: 08-04-2004, 04:34 PM
  5. Question about cutting balsa wing ribs
    By Heliboy247 in forum Hobby Discussion
    Last Post: 05-29-2003, 12:11 AM
