586,108 active members*
3,113 visitors online*
IndustryArena Forum > CNC Electronics > Xylotex > Xylotex Board quit working !
    Apr 2007
    38
    I have a 4 axis board that just quit working.??
    I purchased a 4 axis kit with 425's from Jeff a couple of years ago and have hooked it up to a small mill. It has worked great and have had no issues with it at all. I have about 20 hrs use on my machine now. Last night I was running a program as normal and the xylotex unit shut down. The light was on in the switch because it was getting AC but the power supply shut down. I disconnected the AC took the box apart right away and nothing was hot, no trace smells of smoke and nothing looks burnt on the driver board. I disconnected 24v Vbb from the driver board, hooked up AC, turned the box on and the power supply and the fans came on.The P.S is putting out 28 v. I test across Vbb and GND in on the board with it disconnected and it is shorted out. I also tried this with the motors disconnected from the driver board and it was still shorted out. If I hook up 24 vdc to Vbb again P.S shuts off again. What is the normal cause of this happening and is there a fix other than buying a new board? The system was under low load meaning the steppers weren't being worked very hard at the time it quit and the xylotex system has very low hours on it. Oh what could it be ??
    Kel1
    Oct 2006
    74
    Maybe a little late but I just had the same thing happen. At first I assumed it was the PSU but after disconnecting the board from the PSU, the power supply was running the proper voltage.
    Meanwhile I am tworn if I should invest in another xylotex given it should have lasted longer (3 years) and a 90 day warranty is pretty lame.
    Since they do not do board repairs or offer a replacement discount I might as well look for a different cheaper priced board as there are many now available.
    Apr 2007
    38
    Re: Xylotex Board quit working !
    I was able to remove the dead chip from the Xylotex board and I now have 3 axis instead of 4.
    Obviously had to reset up in Mach 3 and all works fine again !!
    Sent from my SM-G900W8 using Tapatalk
  1. Motors quit working
    By 3Dsigns in forum Automation Technology Products
    Last Post: 10-17-2013, 07:50 PM
  2. G76 quit working on OT-C control
    By g-codeguy in forum Fanuc
    Last Post: 10-08-2011, 05:38 AM
  3. Z AXIS JUST QUIT WORKING
    By BALLISTIKIDD in forum Controller & Computer Solutions
    Last Post: 10-02-2011, 05:24 AM
  4. Machine quit working
    By rnponti in forum Gecko Drives
    Last Post: 07-10-2011, 12:54 PM
  5. ncEdit quit working
    By Cameo in forum Surfcam
    Last Post: 06-28-2007, 06:47 PM
