586,075 active members*
4,316 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Stepper shakes when it normally stand still
    Jan 2007
    Hello,
    I use 3 picstep drivers for my CNC machine. They have done their work very well! But when i started my machine today my Z-axis stepper was shaking. And is not turning correctly.
    I don't have a scope at home but when I touch the switches wich set the stepmode the shaking stops, and returns after a while or when u want to move the motor.
    But when i measure out that circuit nothing abnormal shows up...
    could it be a LMD thats damaged? I use 8k for the current resistor.
    May 2008
    110
    My take on this is when you have a problem and you can touch, push or move a component or wire and it changes the problem it is probably a bad solder joint.
    budP
  1. Stand alone encoder controlled stepper driver
    By JWWalthall in forum Open Source Controller Boards
    Last Post: 10-10-2008, 06:28 PM
  2. 5-phase Stepper/Driver users please stand up.
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 06-19-2008, 05:35 PM
  3. So what does TLO stand for?
    By cncadmin in forum FAQ of DIY CNC Machine Building
    Last Post: 10-23-2004, 11:07 PM
  4. What does CAD/CAM stand for?
    By ynneb in forum FAQ of DIY CNC Machine Building
    Last Post: 08-17-2004, 12:40 AM
  5. What does CNC stand for?
    Last Post: 08-16-2004, 09:31 PM
