586,069 active members*
3,488 visitors online*
IndustryArena Forum > CAM Software > PTC Pro/Manufacture > ProManufacturing Question
Results 1 to 7 of 7
    Mar 2009
    7
    Does anyone know if ProNC has the ability to hide CL retract lines when running Play path, CL Data Input or CL Data Display?
    Jan 2008
    24
    ProNC
    Could you elaborate a little more on the problem you are having? Do you want to hide them? Or are you just not seeing them when you play the path?
    Hammer
    Mar 2009
    7
    ProNC
    I am interested in only displaying the cutters engagement with the stock not the retract, approach or exit moves.
    Softwares such as PowerMill enable you to toggle on/off the display of these lines.
    Jan 2008
    24
    Answer to question
    I have been a Pro-NC user since 1999, and I do not know of any way to turn off the CL simulation moves. I have also asked several of my comrades here at work, and they concurred. DelCam is a different animal all together. You can however place a call to 1-800-prohelp as long as your company has a maintenance agreement with PTC. If there is a way to do it, they will know how.
    Hammer
    Mar 2009
    7
    Thanks for your help.
    Do you know if there are ProNC user guides available anywhere. I found that the PTC online help is fairly vague in detail for the issues I have researched.
    Jan 2008
    24
    Trying to find any significant info on Pro-nc is very tough. You can try the Schroff Development website. They publish and sell books related to CAD CAM applications. They are about the best I have found for Pro-NC.
    Nov 2008
    Sure
    You can change the color of these line to match your background color.
    Under mfg set-up; cl set-up (not sure of exact location) you can set the color based on fed-rate. Hope this helps
