586,089 active members*
3,789 visitors online*
    Mar 2005
    81
    Red face Plus and Minus Reversed
    Hi Guys, could you please help me with this problem. I have a Mach 3 Mill with a Mpg Pendant that I hooked up. When I use the Mpg pendant and move in minus the machine moves in plus, this happens in all axises. I am sure it is some setting in Mach 3, but am just not sure where to find it. The pendant is a usb standard they sell on ebay for $160. Arturo Duncan sells them. Thanks alot, Pat
    If you jog with the keyboard, does it move in the correct direction, or the same as the mpg?
    Mar 2005
    81
    Smile
    Thanks Gerry for your input. Arturo got back with me, and his solution worked.
    In the Mach3 config pins and ports the #1mpg a pin and a port was 2 and 2. Pin b was 2 and b port was 3. Arturo said to reverse them. And it worked. Thanks, Pat
  1. axis goes plus or minus on it's own
    By glentner in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-28-2013, 03:45 AM
  2. Starting at MINUS Z depth problem
    By SScnc in forum Vectric
    Last Post: 09-21-2008, 02:58 AM
  3. g-code reversed??
    By mastertech in forum Uncategorised CAM Discussion
    Last Post: 02-26-2008, 09:20 PM
  4. Y axis reversed
    By Legion99999 in forum Syil Products
    Last Post: 03-04-2007, 06:43 AM
