603,800 active members*
3,549 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > DNC Problems and Solutions > HELP Power supply broken... Bridge rectifier smokes... Coil heats up.
    Jan 2008
    19
    I just wanna know what going on with my power supply. Earlier today I had it up and running no problem. Then I plugged it in again and the bridge rectifier started to smoke up. With no wires going out of the power supply it still smokes up. I am curious if I can fixed this unit by just replacing the bridge rectifier. Thanks
    http://cgi.ebay.com/38V-400W-CNC-Mil...QQcmdZViewItem
    24260
    Probably shorted bridge, pick up a higher current one for replacement, did you have correct fusing in place?
    Al.
    Albert E.
    Jan 2008
    19
    No I don't have any fuses protecting my power supply at all, didn't think I'd need them. I only have them for my motor controllers and my steppers. How should I set fuses up for my power supply?
    24260
    There should be correct fusing, in the primary at least of your transformer.
    Also optional in the secondary leads to the bridge.
    Al.
    Albert E.
  1. Bridge rectifier go poof
    By blfinche in forum Hobbycnc (Products)
    Last Post: 12-02-2020, 06:01 PM
  2. Bridge Rectifier Location
    By cbarsh in forum Bridgeport / Hardinge Mills
    Last Post: 07-11-2008, 05:08 AM
  3. How hard is it to figure out the size of cap and bridge rectifier for a power supply
    By journeyonline in forum CNC Machine Related Electronics
    Last Post: 04-04-2007, 10:31 PM
  4. Switch Mode Rectifier as power supply
    By andy_ck87028 in forum Stepper Motors / Drives
    Last Post: 04-30-2006, 04:17 AM
  5. bridge rectifier
    By osdhillon in forum CNC Machine Related Electronics
    Last Post: 12-30-2005, 04:24 PM
