603,924 active members*
3,987 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Trouble Facing Aluminium
Results 1 to 15 of 15
Threaded View
JWB_Machining Trouble Facing Aluminium 04-08-2009, 05:52 PM
PinMan Is it 6061? I have a similiar... 04-08-2009, 06:06 PM
tstom What inserts? We face a lot... 04-08-2009, 06:20 PM
Geof Very likely you are using... 04-08-2009, 06:12 PM
JWB_Machining I do not know the material,... 04-08-2009, 06:47 PM
Geof I had not looked closely at... 04-08-2009, 07:07 PM
JWB_Machining Yeah i used the Facing... 04-08-2009, 07:16 PM
HuFlungDung If you have a ridge between... 04-08-2009, 07:24 PM
JWB_Machining You Know I Just ran a 1/2"... 04-08-2009, 07:40 PM
JDenyer232 We do this type of facing all... 04-08-2009, 08:13 PM
JWB_Machining JDenyer, Thanks for the... 04-08-2009, 09:27 PM
DareBee Seco makes an Octomill face... 04-08-2009, 09:49 PM
JDenyer232 We use the Octomill for... 04-09-2009, 12:46 PM
dertsap take a couple machine bolts... 04-09-2009, 02:50 AM
HuFlungDung RE: tramming the spindle to... 04-09-2009, 03:17 AM
    Sep 2008
    199
    Hey,
    I'm trying to face a Piece of Aluminum about an inch thick and around 6" x 6". I need to get a beautiful finish on this thing but what I'm getting you can see in the pictures below. I'm Running a 2" Indexable Carbide Shell mill and using flood coolant. i'm Running at 4000 RPM and 32 ipm. I'm sure there's an easy fix for this but i can't wrap my head around it for some reason.
    -JWB
    --We Ain't Building Pianos (TCNJ Baja 2008)
  1. Trouble With Aluminium Feed
    By Brenck in forum MetalWork Discussion
    Last Post: 04-04-2009, 09:48 PM
  2. V22 Facing ?'s
    By bink in forum BobCad-Cam
    Last Post: 02-16-2009, 12:22 AM
  3. Facing Aluminium. I need help with the tolerances.
    Last Post: 06-28-2008, 01:54 AM
  4. Facing problem with aluminium.
    By alexccmeister in forum MetalWork Discussion
    Last Post: 07-06-2007, 12:55 PM
  5. Facing
    By impact in forum MetalWork Discussion
    Last Post: 02-23-2006, 03:24 AM
