588,399 active members*
5,871 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Understanding (European) motor specs - help
    Nov 2004
    78
    I found a servo motor...but it was originally shipped to the European market, so I'm not 100% sure how to read the specs. If anyone could take a look at the attached table I made up, I'd appreciate it. I'm trying to figure out what the torque might be, at the nominal voltage and rpm.
    note: I did change the comma (,) to decimal (.) in this table.
    Thanks!
    -Chris
    24220
    It looks to me that they are 191 oz/inch torque =135 Ncm.
    Al
    Albert E.
    Oct 2003
    399
    I believe the 'n' subfix denotes "nominal".
    Fa is probably axial force, Fr radial. ( = maximum load ratings for the motor axle?)
    J is rotational inertia,
    tm I guess is mechanical time constant (anybody knows how to use this? For setting PID params??? How?)
    Pn is output (mechanical) power at nominal speed (3000 RPM / 60 * 2*pi * 1.35 Nm = 424 W)
    M I believe denotes "Moment of Force", another name for torque. But Al, torque is not force per distance, but force times distance I seem to say that a lot in here . So 135 Ncm = 1.35 Nm = 191 oz*in.
    Arvid
    Nov 2004
    78
    Thanks...looks like a pretty strong motor, which would give plenty of design headroom...
    -Chris
  1. Help understanding "variables" and others.
    By keithorr in forum CamSoft Products
    Last Post: 05-09-2005, 06:54 PM
  2. Replies: 2
    Last Post: 04-30-2005, 11:34 AM
  3. Need help with driver understanding
    By ArtistEd in forum CNC Machine Related Electronics
    Last Post: 02-07-2005, 04:34 PM
