588,563 active members*
4,912 visitors online*
    Apr 2007
    84
    motor tuning problem
    I'm trying to use the auto settting to determine the correct amount of steps on each axis. However, each time I'm off by a few thousandths and try to get closer, mach three comes up with some out of this world umber of steps to change it to tho get to the target number. I'm using cnc masters mill, so i'm nort sure exactly what the leads are on the screws, I'm thinking they are 10mm. I'm also using gecko 201's which are rated at 10 and the motors i'm sure are 200 steps per rev. I'm not sure how to calculate it so i've place ana rbitray number in for the steps. When i use 10400 it's real close, but everytimei try to get closer, mach comes up with some outrageous number to change it to.
    I did check the native settings and changed it to inches, but it didn't seem to change anything
    Please help
    mark
    May 2006
    179
    Hi m8kingit,
    Once you set the native units you should not change it unless you want to alter the complete set up of the machine. Pick either in or mm and stick with it
    Auto setting -
    1st - jog away in the negative direction as far as you can.
    2nd - Go to settings page
    3rd - Click on the set steps per unit located above the reset button
    4th - Select the axis that you wish to calibrate
    5th - Enter the amount you wish to move with out using a negative sign and press enter. Note, the machine will move. A small value of movement should be done first.
    6th - enter how much the machine actually moved then press enter.
    7th - Allow new value and press enter
    Reboot software - VERY Important
    repeat the above using a larger travel value. The larger the travel, the closer you will get
    Happy chip making
    Kirk
    Apr 2007
    84
    Thanks, I was following your steps, with the exception of the reboot, I wasn't aware of that
    Mark
    Quote Originally Posted by ktb100 View Post
    Hi m8kingit,
    Auto setting -
    Happy chip making
    Kirk
    May 2006
    179
    It really makes a BIG difference !
    Kirk
  1. Help with motor tuning
    By harrisam in forum DynaCNC
    Last Post: 05-09-2008, 02:17 PM
  2. Replies: 8
    Last Post: 03-10-2008, 09:35 PM
  3. Motor Tuning
    By dwacker in forum DIY CNC Router Table Machines
    Last Post: 05-01-2007, 03:50 AM
  4. Mach2 motor tuning problem???
    By kombayotch in forum Mach Mill
    Last Post: 03-15-2006, 09:34 PM
  5. tuning problem or what am I missing.
    By REVCAM_Bob in forum Servo Motors / Drives
    Last Post: 12-18-2005, 12:31 AM
