603,785 active members*
17,761 visitors online*
Thread: HURCO BMC20
    Jul 2007
    7
    Unhappy HURCO BMC20
    I HAVE A BMC20 WITH MOTION ERROR DETECTED ON Y, WHEN I TRY TO RUN IN AUTO.IT RAN FINE YESTERDAY AND I HAVE NEVER HAD THIS ERROR. ANY HELP PLEASE
    THANKS STEVE
    I have the same mill I'm trying to get up and running, so I'll start you down the road I've gone down. Power up with the doors open, you need to look at your servo drives, they are on the bottom of the right side cabinet. Look at the middle one of the three, XYZ left to right, what does the 7 segment LED say? Dash-Dot(-.) is normal. There are also 3 LED's beneath the segmented LED, which are lit? The bottom 2(P and MP) should be green if the amp is properly energized and ready to go. I will paste a link to the manual for your drive, compare the troubleshooting info to your current condition. There are much more knowledgeable guys on this forum, I just happen to be going through the same issue as we speak. Let me know how it goes. Go to page 43
    http://www.yaskawa.com/site/dmservo.nsf/(DocID)/TKUR-5EJMLW/$File/TSE-S800-2.1J.pdf
    Jul 2007
    7
    THANKS I BEEN LOOKING FOR A BOOK,WHEN THIS MACHINE RUNS IT IS FLAWLESS,BUT IF IT DON'T WANT TO START, IT WON'T TILL MAYBE THE NEXT DAY.
    THANKS STEVE
    Good Luck Steve, I've been researching what my most reliable and most inexpensive options are for replacing one of these drives without making major changes; when I figure it out, I will let you know just in case your issue is more than just intermittent and you too have to replace your drive. Keith.
  1. Hurco BMC20 with Ultimax 2 control
    By kwmkoester in forum HURCO
    Last Post: 04-30-2009, 11:52 PM
  2. head out of tram on BMC20
    By JWC in forum HURCO
    Last Post: 09-28-2008, 03:44 PM
  3. BMC20-Ultimax3
    By stevieboy in forum HURCO
    Last Post: 08-28-2007, 10:49 PM
  4. Hurco BMC20 Post Prosser help
    By moorport in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-06-2007, 05:19 PM
  5. Hurco BMC20 With Dynapath Delta Control
    By Steve A. in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-21-2006, 07:22 PM
