586,116 active members*
3,338 visitors online*
IndustryArena Forum > CNC Electronics > Viper Servo drives > Viper Software updates , bug fixes
    Feb 2007
    966
    This thread will be for Viper software updates and bug fixes.
    You can also report problems with the firmware .
    In version 2.6, there is a problem with the Bank1 setting for the step multiplier (j-setting) . It starts as a random value and can't be changed. I've fixed this in version 2.7
    If you have this version, just don't use Bank1 (first bank jumper only). Bank 2 and 3 work fine.
    Feb 2007
    966
    Motor jumping when 12Volt is shut down
    Some Viper 200's that i have sent out over the summer (2009) may have a incorrent brownout cpu setting then i programmed them.
    The test is if the motor jumps if the 12V supply is disconnected or shut down. ( Its worse on a slow discharge then a sudden disconnect. ) It can potentially blow the Mosfets
    I noticed this on the bench when i used a different 12 volt supply. When i turned off the 12V leaving the main on, then motor jumped. When i turned it back on one of the upper mosfets were blown.
    If you have drives that do this, you may want to return them to be reprogrammed.
    Larry K
    Sept 3 2009
    Dec 2008
    15
    Hello Larry,
    I bought two if your drives this summer, one to replace a problem plus another to make my 4th axis. I am not running 12 volts, I am running 72 volts, and no matter what when I turn the boards off they turn a bit and my zero settings are not correct. I have checked and replaced different things, to no avail. Then I read this post and see my problem. Is there a way to program without the sending of the boards in? I am in Texas and a real hassle to send the boards, because of the 26 mile trip from where the machine is to get to a place to mail them. Also have slow internet, have to tether my telephone to access internet where the machine is. My internet address during the week is [email protected].
    Feb 2007
    966
    No, sorry the drives arn't field programmable at this time, i should have that in the new year.
    You can return the drives for reprogramming or make the main power turn off first and have the 12 volts turn on/off with a relay controlled by the main DC voltage.
    Larry
  1. Syil X3, X4, X4+ enhancements and fixes.
    By Des Jacobsen in forum Syil Products
    Last Post: 01-09-2011, 11:41 PM
  2. Bug fixes?
    By MrWild in forum Dolphin CAD/CAM
    Last Post: 06-11-2008, 05:40 AM
  3. New Viper software with current control
    By Larken in forum Viper Servo drives
    Last Post: 01-10-2008, 08:32 PM
  4. Alarms and fixes
    By HAILINHAAS in forum Haas Mills
    Last Post: 11-14-2007, 04:29 AM
  5. Machine shop screwed up - who fixes?
    By carlnpa in forum MetalWork Discussion
    Last Post: 08-18-2005, 02:20 PM
